Home > Puma (Tdci) > Puma 2012 Front Axle
Page 6 of 15 <123 ... 567 ... 131415>
Dinnu
I had made quite a bit of reading and I was informed quite well on this topic, as my 90 has a defective axle. But still this is another shock, especially on, the dare to say, bribing part. I have since painted my axle because I disliked the rusty appearance, but there were no oil stains in that area prior to painting.
I wish I have the balls of Payney (which I think should change the username to "Pay? Nee" - quite a few Dutch here that would understand it), but going through a law suit on an axle that has not yet failed would be very difficult. I do tow a rather heavy boat, and always with the 'What would happen in an emergency brake situation' at the back of my mind. As such replacing the axle case with a good friction welded one is in the plan for this winter.
Hats off to Payney. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #961728 15th Aug 2022 12:41pm
Dinnu
Race.it wrote:
Do we know when they outsourced this? Dates, did they bring it back in house later or does it affect all newer ones.
Anybody have photos of the cracks, my axel is not under sealed but could not see cracks but maybe looking in wrong place.
Good luck with the fight and thanks for publishing your findings so far
It is very easy to distinguish between friction welded (good) and mig welded (bad) axles.
Friction weld created like 2 rings around the weld. This is next (maybe 3cm away) from the swivel hub flange. With Mig weld, the joint there is smoother. Note that the horizontal welds, that join the upper half to the lower half of the axle have always been mig welded.. but do not worry about that.
2010 is most likely to have friction weld, but feel free to post a picture here and sure someone will be able to verify.
Having said that mig welded axles are bad, there was also an improvement in about 2013... so later vehicles should be ok. But not as good as earlier friction welded.
I have posted a picture of a late 80s friction welded axle here:
https://www.defender2.net/forum/topic33029-165.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #961730 15th Aug 2022 12:49pm
Can you expand on that last comment there, Dinnu? What do you mean by "an improvement in about 2013...But not as good as earlier friction welded"? Darren
Post #961737 15th Aug 2022 1:26pm
Dinnu
Hi LRA, I guess you want to know what JLR (or Tata as referred to by Payney) did. I wish I know too, but for sure they kept mig welding them till the end. If it was a change in their robotic welding parameters, or did mechanical design change to have deeper welding or they fired the Indian guy welding the axles and hired a new one, I guess no one will know.
Payney1000 wrote:
Anyway after 6 months of the new axles coming form India Landrover were fully aware that their was a serious problem.
I believe that there were just over 2 years of badly fabricated axles... so I let you make your own conclusion also from what was disclosed by Payney.
See also some more of my comments on this part of the recall thread:
Post #961739 15th Aug 2022 1:42pm
Gasket
This is shocking, again all credit to Payney for sticking to his guns and mate - thank you for sharing this on the forum.
Is it worth just confirming (so that we can all run outside and check our Defenders before everyone starts panicking) that this is believed to only affect some of those axles that had been mig welded post 2010 and that the friction welded axles were unaffected.
Here is a picture of my front axle from a MY2010 D90 SW. If I've understood this and the other thread (https://www.defender2.net/forum/topic33029-180.html) correctly then a friction weld is identified by having a double seam. I think that mine is therefore unaffected, wish I'd known that before I bought and fitted the recall bracketry.
Post #961747 15th Aug 2022 2:47pm
htb2
Wales
Gasket,
Yours is a friction welded axle so not affected by the recall.
David
Post #961748 15th Aug 2022 2:52pm
Payney1000
France 2012 Defender 110 Puma 2.2 USW Santorini Black
Guys please see the following photos.
This photo shows Mig welded to the left of the bracket.
The following photo is my axle after it snapped very clean cut showing welding failure.
This photo was straight after the crash at 60 miles a hour
Hope that helps understand. 👍
Post #961753 15th Aug 2022 3:11pm
Gasket wrote:
... I think that mine is therefore unaffected, wish I'd known that before I bought and fitted the recall bracketry. ...
I know my '07 is friction welded and outside the recall but fitted the brackets nonetheless for peace of mind. It is disturbing how flimsy the running gear of my Defender is when compared to that on my 80" Series One.
Post #961754 15th Aug 2022 3:12pm
Gasket
htb2/blackwolf. Thank you very much.
Payney - that is awful. Thank goodness you got out of it safely.
Post #961758 15th Aug 2022 3:43pm
Payney1000
Gasket,
I wish i could say i was ok but not the case. I damaged my right shoulder and ripped the muscle from my chest bone to my shoulder. still reduced movement.
But here is some photos what it was like and still is lol
very lucky but if it was not for a ditch 5 foot deep full of water it could have been worse.
Post #961760 15th Aug 2022 4:00pm
Yes, the "what ifs" don't bear thinking about - a school party on push bikes in the wrong place at the wrong time, for example, although I don't suppose that JLR would be allowed to ignore the problem if that had been the case.
I am amused by the writing in the dirt on your rear left side panel, something of an understatement, I think!
Post #961769 15th Aug 2022 5:01pm
Payney1000 wrote:
... This photo shows Mig welded to the left of the bracket.
I would have hoped that the obvious flaw in the weld indicated below, complete with rust, would have rejected this axle during build. The near criminal negligence of all this makes me very angry.
Post #961771 15th Aug 2022 5:05pm
Dinnu
Could have been a Tata supplier, who knows. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #961773 15th Aug 2022 5:17pm
Dinnu
Well spotted Blackwolf. Thumbs Up
I would really love to see some close up pictures of the failed weld on Payney.
It is also disturbing that all failed welds I have seen are on the left side of the axle. What did they do differently on the right side? I would have thought that the right side is more stressed due to the higher unsprung weight by the final drive / differential. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #961774 15th Aug 2022 5:24pm
trevorg
France 2012 Defender 90 Puma 2.2 SW Indus Silver
Picked up on this thread, and unsure about the niceties of welding, so had a look under my 2012 90. There is a weld to each but with a single standing seam. Should I be worried?
Post #961778 15th Aug 2022 5:38pm
