Home > Maintenance & Modifications > New swivel housing ball needed.
Page 1 of 4 1234>
keith
Obviously the oil seal has failed. There is some pitting on the ball.
Does the ball need replaced or just the oil seal.
Post #945012 8th Mar 2022 8:38am
donmacn
If that’s as pitted ‘in the flesh’ as it looks in those pics, then I’d say yes - you need a new ball. Is it just the one side?
In the real short term, you can do a ‘field repair’ where you cut the old seal off, including the retaining plate. You then carefully cut the new ones. The rubber seal can be glued together once around the neck of the seal, and the wire retainer/strengthener can actually be ‘unwound’ (rather than cut) and ‘rewound’ and again, superglued.
Reassemble and fill and off you go. However with a ball that pitted, it wouldn’t last long. Bite the bullet time I’m afraid.
Edit - looked at the pics again and something occured to me. I take it, if you jack the wheel off the ground, grab it at 12 and 6 o clock and give it a good shake, that there’s no movement? If the swivel is loose on it’s bearings/pins then that could make it leak. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #945013 8th Mar 2022 8:47am
keith
Yes indeed it is pitted but the dealer just had it apart replacing the CV joint and halfshaft. Guess what? It wasn’t leaking before the repair. The other side is clean and dry.
Post #945015 8th Mar 2022 9:14am
donmacn
That’s a b****r.
In which case, and having another look, where the leaking is focussed on the bottom of the ball, what I was saying about badly adjusted bearings might be more relevant. Maybe they’ve left out shims under the top pin, causing the whole thing to be loose?
Bit of a tough one I know, but any mileage in making sure they fix the problem they caused? Donald
in the past..
Post #945018 8th Mar 2022 9:22am
keith
Post #945022 8th Mar 2022 9:30am
landy andy
Sorry. But that requires a new swivel joint. Perhaps made worse by recent works, or possibly had no oil in before. But that is too far gone.
Post #945024 8th Mar 2022 9:37am
keith
I don’t have any issues replacing and repairing. Just a shame it wasn’t done when it was stripped out only a few weeks ago.
Post #945027 8th Mar 2022 9:51am
landy andy
Agree completely. I wouldn’t have gone near that without already having the replacement parts. Can only assume they didn’t want to upwelling, but will now cost you more.
Post #945036 8th Mar 2022 11:23am
keith
Every trip into the dealer for a repair means coming out with another. Booked in next week.
Post #945081 8th Mar 2022 6:29pm
Don't forget that it is unlikely that the dealer touched either the pins or the seal if all he did was remove and replace the halfshaft and CV joint. Once the stub axle is off, the CV and halfshaft just pull out, there is no need to touch the swivel or pins.
I am however extremely surprised (especially if it was a main dealer) that you didn't get the call to say that you need a new swivel ball, seal, pins, bearings etc, and that it will cost you a cool £2.5k for parts and labour. Dealers don't usually pass up that kind of opportunity.
It definitely needs the ball and seal replaced, by the way, you won't stop that leaking.
Post #945083 8th Mar 2022 6:47pm
keith
AWWCH. Thanks wolf you’ve just made me choke on my false teeth.
Eh! 2.5k for a swivel housing Shocked Shocked
Better cancel the Easter hols then. Is that honestly the cost of new housing and bits. Jeeeeesh I’m in disbelief.
Big Cry Big Cry
Post #945085 8th Mar 2022 6:55pm
Retroanaconda
Couple of hundred quid in parts and a morning of your time.
Post #945086 8th Mar 2022 6:57pm
Screbble
That looks to me as though the swivel pin bearing has failed. If you jack it up you’ll probably feel the play at 12 and 6 o’clock as stated above.
I hope the remedial work goes well and isn’t expensive - easy enough to tackle yourself.
Is that a Gwyn Lewis Sumobar drag link I see?
Post #945087 8th Mar 2022 7:01pm
keith
Eagle eyes Screbble. Yes all running gear is GL. Usually shiny stainless.
I’m on the hunt for a genuine kit if you keen to help the search Thumbs Up
Post #945089 8th Mar 2022 7:06pm
Screbble
Thumbs Up
Im also in the stainless GL steering gear club (with the poly boots!) and the Discovery drop arm conversion Thumbs Up
That doesn’t help you - I bought my swivel kits off the Bay of E - Bearmach - about £160 ish (ABS version).
Trouble was as part of ‘the job’ I then wanted to replace everything - discs, callipers, bolts, mud shields (don’t say it!), YRM stainless hardware etc.
Too shiny to use now Neutral
Hope all goes well Thumbs Up
Post #945092 8th Mar 2022 7:18pm
Page 1 of 4 1234>
