Home > Maintenance & Modifications > New swivel housing ball needed.
Page 2 of 4 <1234>
keith
Post #945093 8th Mar 2022 7:20pm
Screbble
Your swivels will soon be as clean as these 👍
Post #945094 8th Mar 2022 7:22pm
keith wrote:
AWWCH. Thanks wolf you’ve just made me choke on my false teeth.
Eh! 2.5k for a swivel housing Shocked Shocked
Better cancel the Easter hols then. Is that honestly the cost of new housing and bits. Jeeeeesh I’m in disbelief.
Big Cry Big Cry
Don't panic, the figure was guesswork based on what experience I've had in the past of dealer pricing. It could be much less (or more, I suppose).
Sorry if I caused palpitations. Very Happy
I've just checked and a new genuine ball is £250, so add a seal and gasket or two, and if needed pins and bearings, and you'll be around £500 per side in parts at a main dealer. Then add around four hours labour at £100+vat per hour and you'll not get much change from £1500 if doing both sides, I fear.
Post #945101 8th Mar 2022 8:21pm
keith
Screbbie is showing off now. That's pornographic pic right there. I'd frame it. Clearly hasn't see the winter gritters evil salt yet. Lovely though. Ahhhh them wer the days.
Post #945102 8th Mar 2022 8:33pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
keith wrote:
Every trip into the dealer for a repair means coming out with another. Booked in next week.
There's your problem. Find a decent indy Thumbs Up
OEM swivel kit is under £200. Few hours labour, job done Thumbs Up
Post #945107 8th Mar 2022 9:38pm
Buttons
Ireland
I'm only a newish newby so go easy. I may be completely wrong.
I would think there is a possibility the drive shaft oil seals may have been damaged during the recent work allowing diff oil into the housing or pressure to build up if the breather is blocked?
Just a suggestion, and to keep in mind replacing the swivels may not fix the problem if the oil seals have been damaged with diff oil leaking to the swivel.
A good sniff required?
Sorry, new to landrovers, rebuilding a 110 from the crankshaft up, but this seems too much of a coincidence.
Post #945113 8th Mar 2022 10:54pm
Buttons
Ireland
Thumbs Up
Post #945114 8th Mar 2022 10:56pm
Screbble
Good point about the oil seal. Definitely worth looking into.
The axle/driveshaft oil seal sits in the rear of the swivel ball so it would be replaced as part of that replacement process (one would hope!) Thumbs Up
PS make sure you install it the correct way round.
Post #945123 9th Mar 2022 6:52am
Screbble
For the avoidance of doubt…
My reference to fitting the correct way round was in relation to the oil seal not the swivel Rolling with laughter
Post #945124 9th Mar 2022 7:12am
excossack
Greaseable TRE's. - Available as off the shelf items? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #945130 9th Mar 2022 8:29am
keith
Exo. Yes. Gwyn Lewis.
Post #945131 9th Mar 2022 8:32am
excossack
cheers 1999 Defender TD5 110
Regards
John M0VAZ
Post #945132 9th Mar 2022 8:37am
Screbble
As Keith says - yes available from Gwyn Lewis in a number of options. Go for the poly boot if you are going to purchase.
Other manufacturers and suppliers available of course but you can’t go wrong with GL Thumbs Up
Post #945174 9th Mar 2022 5:24pm
ksv
Russia 2007 Defender 110 Puma 2.4 SW Keswick Green
Hi all
Mine was curd by the halfshaft seal replacement.
Post #945244 10th Mar 2022 5:57am
ksv
Was cured... Sorry
Post #945245 10th Mar 2022 6:00am
Page 2 of 4 <1234>
