Home > My Defender > 1988 Shire Blue Landrover 90 Restoration
Page 19 of 28 <123 ... 181920 ... 262728>
Co1
Looks great as always. Keep the updates coming!
Post #942867 17th Feb 2022 7:13pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Really enjoying this build 👍🏼 Roaming around 🇳🇴🇨🇭
Post #942868 17th Feb 2022 7:15pm
Dinnu
Thank you. I think there will be plenty of updates to come, as far from finished Laughing 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #942878 17th Feb 2022 8:21pm
Dinnu
And top side of the seatbox.
Post #942986 18th Feb 2022 6:49pm
Dinnu
Engine out again, due to an oil drip after starting the engine to test.
What I noticed is that the rear main bearing cap is 0.15mm further in from the engine block. Very strange, I have not checked it before disassembly. Those T seals were very difficult to install, and I do not have the special wedged to guide them in, but I trust that the main bearing cap is installed correctly. Crank still turned freely when the main bearing cap bolts where torqued 🤷 So most likely I did not apply enough sealant to cater for that 0.15mm gap. Fingers crossed, it is ok now.
Post #943073 19th Feb 2022 6:25pm
Dinnu
Seat box is in, at least kind of. Then realised that I forgot to re glue the original insulation foam back Embarassed
Between the battery box and seatbox I applied double sided tape. Acts as a barrier, although there is also good layers of paint and galvanizing on the battery box, but helps to seal too. Quite sticky stuff I use, so need to wrestle a bit to align all the rivet holes.
Sorry, bit of a dark photo.
Post #943253 21st Feb 2022 10:57am
L110CDL
Fingers crossed for you, hoping that you have fixed the oil drip and the seat box is looking good in it's place Thumbs Up Clayton.
Keeper.
Post #943362 21st Feb 2022 9:34pm
jimbo55
Noticed your image of the engine out again, Have you considered fitting an intercooler to the engine? I know it isn’t an original item and you’re definitely doing a good job of restoring your vehicle, but it probably would be a worthwhile addition to try to increase the engine life especially given the bad reputation the 2.5td has.
Post #943367 21st Feb 2022 9:49pm
Dinnu
Thank you Clayton.
Next:
Few rust pin holes in the blower scroll to fix. Taken apart because the flaps lost the foam, and the steel to steel rattle used to drive me crazy. In fact the heater setting was never set on all cold or all hot for that reason. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #943371 21st Feb 2022 9:53pm
L110CDL
Will be great when the jigsaw is all back together, as your doing it, it will be better than new Thumbs Up Clayton.
Keeper.
Post #943374 21st Feb 2022 9:58pm
JOW240725
So many pieces!! Once the oil leak is fixed you must feel like you're on the home straight? James
Instagram @suffolk_rovers
Post #943405 22nd Feb 2022 7:12am
Dinnu
Hi Jimbo, I have been toying with that idea since I removed and opened the old engine.. so that is quite some time now Embarassed I am really confused what to do, keep it original or modify. I really wish to keep it looking stock. I do not like engine bays cluttered with pipes and tubes going all over the place, with pieces of steel, and rubber/silicone all over the place. Now that is the cosmetic part. From technical side, I have read very conflicting information. The 19J have a boost of 9psi. A rough calculation, assuming an isentropic compression, air inlet at 40dC, after compression is about 85dC. I guess an intercooler can drop the temperature a bit, but then looking at how close the exhaust manifold and inlet manifold are, I am doubting the real benefits. What I have understood is that the problem lies more in the compression ratio of the engine itself. Compressing more air in will undoubtedly increase the compression temperatures further Big Cry So if the charge air temperature is cooler, and more mass can enter the cylinder, I would be concerned if the final compression will be even hotter.
What I plan to fit though is an EGT monitor. It will be barely visible, as I can control the amount of fuel and hence the temperature with my right foot. The problem is however I do not know what is a safe EGT value for this engine.
I have also not used any components of my earlier engine, original engine number was 19J11xx. All components are from a newer 19J with engine number 19J31xx. Some date codes that I could find is that it was build around October 1989. That would give me one of the latest 19J engines, which were improved . I do not know if the head/pistons (weak points) on this engine were the original ones, but can state that when I opened it, the head was in perfect condition, and only very minor cracking on 2 pistons. The only history that I know of this engine is that it powered a 90 with a heavy trailer from the UK to Malta Laughing
My previous engine had a very hard life. I regularly towed heavy trailers, and I did become a bit careless with the cooling system. Probably not even a tdi would have survived my abuse Whistle 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #943408 22nd Feb 2022 8:03am
Dinnu
Home run Smile many times I am get that feeling... until I see all the small parts that still need to be tackled Laughing I cannot yet promise a year when I can update with the adventures instead of the resto. But I can assure you I am enjoying the resto as any adventure. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #943409 22nd Feb 2022 8:07am
JOW240725
I'm very much enjoying the resto journey too, so no hurry! One part at a time.... James
Post #943412 22nd Feb 2022 8:57am
Dinnu
Back to the engine durability, I wonder if it would have been a good idea if I simply got 12J (the normally aspirated) pistons, and shaved of a bit of their tops to reduce the CR.
Looks like every 0.25mm removed from the piston will reduce the CR by 1. 12J and 19J runs with CR of 21:1.
For comparison, the Tdi run at 19:1, TD5 run at 19.5:1, the 2.4 run at 17.5:1 and the 2.2 run at 15.6:1
Post #943424 22nd Feb 2022 11:12am
