Home > My Defender > My 110 MILLIE. |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10833 |
So Millie had a thirst for water again https://www.defender2.net/forum/topic78905.html
After all the reply's, i decided that is was the same symptoms as the first head, so i had this parcel delivered to my indy last week Click image to enlarge Then on the Saturday just gone he put the new head on with new head bolts Click image to enlarge It seemed the best time as i had this for a few weeks now, so i asked my indy to put this on Click image to enlarge Fitted onto Millie Click image to enlarge My indy said that it fitted like a glove, no problems what so ever After using Millie for a few days now with the new head on, first impressions are really good, seems to pull better up hills and pulling away from a stand still is just as good, she seems to be breathing better as well. The new head is a Turner performance head for a 300 Tdi. Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
23rd Jun 2021 7:21pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20552 |
Glad that you got it sorted in the end, probably at a good time before any other issues too. KEEP CALM AND Drill ON
๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
23rd Jun 2021 8:53pm |
Thanks Steve and hopefully no issue's for a little while at least Clayton.
23rd Jun 2021 9:28pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3686 |
Good news!
24th Jun 2021 5:13am |
It is good news Co1
So a little update with the new head on for nearly a week, all good in the water front, Millie's thirst for water has stopped now now i have had time to asses the new head, it's so different to the standard head, so much better when pulling up hills and changing up the gears, no effort, just pulls, i would recommend one of these heads over a standard one any day, i'm well chuffed with it Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
25th Jun 2021 7:20pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5216 |
shame about the head going, but nice little upgrade there for a replacement. I bet millie growls with the K%N filter in. My 300 used to do with ITG filter in, used to growl when you powered away, and sounded aggressive, when you put your ear next the air vent. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
29th Jun 2021 8:36pm |
Thanks Procta
I haven't heard her growl yet but she does sound really nice on tick over when your ear is near the exhaust exit Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
1st Jul 2021 7:52pm |
I have been getting use to the new head on and i'm loving it, i have put my original fuel injection pump back on with the standard set up and tweaked it slightly myself and i'm happy with the way she is running now. I had to have a new fuel tank fitted as my old one was damp on some edges, that tank was only the second tank put on, so it has done really well and with the new tank and the Turner head, early stat's are indicating that i am getting between 50-60 miles more per tank, i am still monitoring this with a few more fill ups
Millie has also had a MOT and she . . . . failed but it was the drop arm link bush, to much play, so as my MOT 'er is my old indy he had a new arm replacement in stock as it was better to change the lot and then she passed He did say that Millie passed the emissions quickest he seen her do I have been busy with the water pipes on the engine as they were to close, in fact rubbing on the water pump wheel / belt, i was lucky that i spotted it before they had rubbed through, so i have re-routed both pipes so they miss the wheel / belt by a long way, really pleased how that went I also replaced all of the air intake pipe work from the snorkel to the air filter housing, i have replaced it with original / genuine rubber pipes, but the " dump valve " is britpart as they were the only supplier of this part, it fitted all okay, so that was a relief the last pipe to were it attaches to the snorkel had a split in it, this is what made me replace the whole lot but when i took the joiner out i realised it was the a piece of the old plastic pipe that originally fitted to the inside to the snorkel, i thought " what a bodge job " i must have been very lucky that no water found it's way into the engine, so i replaced it with some flexible silicone air / vent hosing and i am happy now that the job has been done properly As my snorkel was off in this process, i took some pic's so you could see how it works Click image to enlarge Click image to enlarge With the big help from Lord-Haggis, he sent me his old soundproofing and i finally fitted it into Millie and i had to make the hole for the bonnet release as well as some other modifications to make it fit nice and snug Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge I'm very happy with it all and i didn't realise how much sound the old soundproofing kept out as i had removed the old soundproofing out to take the pic's and when i drove Millie for the first time with the " new " soundproofing in, well she is soooo much quieter now While all this was being done and sorting Millie out, she had a service and she had all the oils changed as well, transfer box and both axles, the gearbox was done in the service. I am starting to do this once a year from now on as she does work hard and for the price of oil is far less than a major part failing, so were up to date with Millie's on goings but i have a few other things to get on with now that all the above has been done Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
27th Jul 2021 8:18pm |
The sound proofing is good isnโt it, it does reduce noise and vibration but another thing I notice is it overall it makes things feel more solid as well which is good.
Good news with the MOT as well ๐๐ป KEEP CALM AND Drill ON ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
27th Jul 2021 9:00pm |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 591 |
I thought I had been busy but Millie is getting the VIP treatment. Suppose itโs what keeps them running well though.
27th Jul 2021 9:18pm |
Thanks Steve, yes it is a better and nicer fit in the cab
I read your update and you have been busy, looking really good what you have done and it's always good if you can keep on top of the list of things " to do " Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
27th Jul 2021 9:37pm |
looking neat there! you want some sill covers that go over the floor and inner sills. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
27th Jul 2021 11:01pm |
Thanks Procta
I did think of the sill covers but i do like to take the mats out and give her a good clean and i think she looks good without Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
28th Jul 2021 7:36pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3461 |
Cockpit looks smart 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
28th Jul 2021 7:49pm |
