Home > Expedition & Overland > Henri the 110 goes pop top! |
Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025 |
Hi Simon, ours is an Ostrich wing. More more shade than a dry cover, great heavy duty wing.
Cheers Jim. |
22nd Mar 2021 6:51am |
Times been moving on & had a few things done, front end HD bumper with swivels & headlight guards. Ended up having to mount the HL Jack on the front ( not ideal but run out of space everywhere else). Also custom kitchen boxes.
16th Apr 2021 5:37am |
After changing the suspension so she sits slightly higher I’ve gone for Gwyn’s mega props with the heavier 20/20 joints. DC on the front which will help with the slightly increased angle. Impressed with these, extremely easy to grease.
23rd Apr 2021 7:26am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
Looking great!! Must be difficult to know where to stop with upgrades etc? James
23rd Apr 2021 7:43am |
Morning James,
Weakest link in the whole set up was the rear prop ( everything on the drivetrain will be Ashcroft HD) A good friend has had an issue with a slightly lifted Puma so thought it would be prudent to change the front prop as I wouldn’t want an issue whilst travelling down the west coast of Africa |
23rd Apr 2021 8:19am |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 560 |
Looking good, I need to find a place for a Hi-Lift yet!
Is it actually lifted or did the new springs just put it back to normal height? I’d be interested in your bump stop clearance all round if you ever fancy measuring it! I’ve got genuine HD springs all round with rear inner helpers and an Alu-Cab roof and wasn’t planning on changing the front prop but maybe I should! 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
23rd Apr 2021 12:11pm |
Sorry for the late response, because we are quite heavy Gwyn recommend
OME 2751 front OME 2754 Rear +25mm bump stops, have gone for OME std size dampers & carrying one front plus one rear as spares. I would say we are 1-1.5 inch lift that’s why I’ve changed the front prop ( rear needed changing to something stronger anyway) I will get back to you on measurements ( drives on an incline so need to get her level) Cheers Jim. |
25th Apr 2021 4:59pm |
Forgot to mention running 255/85/16 MTR’s so it gives a bit more clearance on the arches too.
25th Apr 2021 5:02pm |
No worries, many thanks for the reply Jim.
Very helpful info, with my HD springs on the front and standard height Koni shocks it’s running at about standard height I think due to having a Warn 8274 winch and bumper and also the Wolf spare on the bonnet. I’m also running 255/85/16 (KM3’s) The rear isn’t fully kitted out yet so don’t know where that will end up! I’ll see how it performs but might swap to the OME springs if needed. Wondering as well, is your front axle central now with the lift? Mine seems to be 10-15mm further out on the drivers side! Current stance... Click image to enlarge Thanks again, Russ. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
25th Apr 2021 8:48pm |
db950, bump stop front 95mm ( standard bump stops) rear 115mm ( Gwyn’s +25mm) did have +25mm all round but the front bottomed out off road.
18th May 2021 9:14pm |
Big weekend for the truck....
Ashcroft ATB’s front & rear / HD shafts all round / HD cv’s / M82 output shaft / new clutch slave etc / discs pads all round / wheel bearings all around / n/s rear hub / removed the centre exhaust box / countless bearings / tre’s x 4 / & new bolts....now skint |
18th May 2021 9:22pm |
Thanks for the measurements, mine are very similar(without the +25mm bump stops) Not far off standard 110 clearances actually, most quote about 80-90 mm fronts and 125-140mm rear unladen, so think I’ll try it with the standard front prop for a start and see how it goes. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
20th May 2021 5:39am |
Short on storage so having to improvise ( to carry fluids) and finally sorted the food draw out! Just needs powder coating now.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
25th May 2021 5:08pm |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1364 |
great work on this, the rear window blank, how have you addressed the wiring on the inside?
where is the blank from, MUD? |
26th May 2021 8:03am |
