Home > My Defender > Puma to LT1/8L90 Restomod |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3316 |
Loving your work. It's going to be a very special truck. WARNING.
This post may contain sarcasm. |
28th Feb 2021 7:59pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7907 |
Amazing work!
Have you chosen a finished colour scheme/look? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
28th Feb 2021 8:22pm |
mrfirepro Member Since: 06 Nov 2020 Location: kent Posts: 231 |
Well yes, I have chosen a colour scheme... chose one on Monday, chose a different one Tuesday, Wednesday yes you guessed it a different one.
Every time I see a nice defender, I change my mind to the colour of the defender I've just seem.... It is a problem because the bulkhead will be painted the end of this week and I need to choose a colour, just a note my calipers are going to be orange with black logos...... these ones Burnt Orange Click image to enlarge White Keswick Green There is a Metallic British Racing Green that LR use on the range rover and it's lovely, this is the closest I can find on a defender Click image to enlarge Red Click image to enlarge |
28th Feb 2021 9:05pm |
engine and gearbox arrived from the states yesterday
this is what you get with the package Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge I'm hoping a lot of it is going to be obvious as the installation guide doesnt seem to contain much details, time will tell. |
5th Mar 2021 7:22am |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2900 |
I thought you where going manual? Thats the PCS kit I have Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
5th Mar 2021 7:24am |
Have you any gauge drivers? There are small black boxes with PCS stickers on them. Andy
5th Mar 2021 7:30am |
I'm really pleased your following this, no what are they?? |
5th Mar 2021 7:37am |
you should have a Chevy performance loom for the LT1.It will have a good few wires labelled for rev etc but you just ignore them. Then with the PCS kit you need the loom and gauge drivers which pick up the oil temp rev etc. You basically fool the LR ECU to think all is normal engine wise by disconnecting a few wires and then the LT1 ECU and Gauge driver do the rest. The guys that got you the PCS shifter should be able to get you the bits that are specific for the defender install but give me a shout if you get stuck. Andy
5th Mar 2021 9:55am |
Also are you planning to run aircon? Andy
Great sharing this help James
5th Mar 2021 10:03am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
<deleted> 1988 90 Td5 NAS soft top
2015 D90 XS SW Last edited by Martin on 5th Mar 2021 10:11am. Edited 1 time in total |
5th Mar 2021 10:06am |
So my plan with the electronics is to use either the kit from Futuranet or from Nick at RW engineering. My info is they both replace the LR ECU. I'm also integrating a TPMS system just to make things really easy. Both options I'm told are all I need.
They both have pro's and con's but the RW solution has a seperate display installed into the cluster to provide lots of other info such as gears, temps, pressures etc etc..... I'm not sure if I've got anything right as I'm strill trying to put this together so please keep your advice coming. Hope the above makes sense. I am installing AC. |
5th Mar 2021 10:10am |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 486 |
A M57TU/N57 is capable of 450HP when tuned so I cant see how the TD5 can realistically match that? |
6th Mar 2021 5:46pm |
Have you any info on the digital display Paul? Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
8th Mar 2021 8:06pm |
