Home > My Defender > a 130 itch |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8020 |
Well lockdown is well underway. so was thinking of the next upgrades that could be done.
Ideally would like a full length black roof rack. As per other post will upgrade headlight loom plus fit some better bulbs front. Plus will fit some rear work lights, ideally off the rack. Plus an upgraded reversing light. If funds really permit a webasto coolant heater would be nice, will mean no static running when shower is needed! for the now, its a strip out of the shooting kit and a repack with the camping kit - i want to be ready to go when lockdown lifts! Rear cleared out and 'tea' shelving back in. i forgot how big it was back there! Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
7th Jan 2021 8:04pm |
130 is still providing Stirling service, out on log duty last few days.
Click image to enlarge Have a boomslang loom plus some rear spot lights to add now, along with brighter headlight bulbs. Big purchase after much consideration, patriot 3.5m black rack enroute, have asked them to space the feet sufficiently to fit in the front runner table. On fact space for two! Due in a week or so. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
13th Jan 2021 8:39pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10742 |
The roof rack will make it look very different again, will look proper 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
13th Jan 2021 8:57pm |
Patriot rack made to order due end of the week! will then need to find time to fit it!
Have some rear spots to add to the rack so need to get the wiring sorted for that off a dash switch (thank you TJ101) Fitted an interior light under the gull wing door to aid cooking of an evening. Even now have the perspex to fit under the roof tent to fill the gap between roof tent and awning, something thats been on the list since talking about it 18mths ago! Looking forward to fitting the rack but not looking forward to cleaning it first which should really be done! Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
26th Jan 2021 10:46am |
Racks arrived! Cheers
3rd Feb 2021 11:05pm |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
Looking forward to seeing it !
I’ve just put a deposit down on a 130 so will avidly be watching this thread. I’ve got a Hannibal on my 110dc which clearly won’t fit my 130 but it looks as though Tembo make a near identical rack. Did you ever look at them or were you set on Patriot ? https://www.instagram.com/hustynminepark/ |
3rd Feb 2021 11:31pm |
I have a hannibal on my 90, works well. But to low to get table under.
Tembo one, sits a fair bit higher from memory and slats run across? I think from research I had a height issue, too high this time with tembo. They also never replied to enquiries. 110 usw rack will fit, check my other pics. Patriot but default almost, they rang back on an enquiry and built to order with leg spacing. I know product is good for test of time so went with gut on it. More £££ but they were more accommodating and flexible on changing dims to suit my needs. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
4th Feb 2021 8:37am |
Well i have had the rack for a week, just dont seem to have time to spend sorting it. Starting to get there now.
Click image to enlarge Its a Patriot rack made to order for 130 with a double cab front support and an adpated (900mm spacing) rear double feet back. Table fits between the feet supports so needed to be wider than their standard set up. Click image to enlarge Table supports now fitted. Roof tent studs fitted. Just the awning mount to sort and the Perspex for the rear (rain guard for the gap between awning and roof) Click image to enlarge Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
8th Feb 2021 10:07pm |
That is a very nice rack there James and glad your sorting it out 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
8th Feb 2021 10:17pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
Found the clear sheeting a excellent mod, i used AXGARD Polycarbonate
keep the rain out between the awning and rack Click image to enlarge California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
9th Feb 2021 8:33am |
Good idea that!
have you fitted RT and awning to your new rack yet? pics its hard to tell but i guess thats the old one? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
9th Feb 2021 8:16pm |
Rack looks Black to me in picture ? Yes, all fitted to new black rack California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
9th Feb 2021 8:42pm |
i just thought it was a dark day reflecting the light! good thats it all on, so now to use it! Cheers
10th Feb 2021 7:52pm |
Well its on and outside!
20th Feb 2021 1:46pm |
