Home > My Defender > a 130 itch
Page 16 of 21 <123 ... 151617 ... 192021>
jst
i think they are alot of money for what they are and you could make your own cheaper, however they come with everything you need to fit and if time is tight are the right answer. i think rear of both front and rear wheels are the most beneficial keeping it off the outriggers at the front and the rear crossmember on the rear. i have welded up various farmers outriggers and crossmembers over the years, now after repairing i fit these too as don't want to revisit it!
they are one of the simplest and easiest mods to do for the highest long term gain.
If you have the time then make your own, if you want a hassle free option with everything you need then fit Gwyn's. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #874846 27th Dec 2020 6:40pm
jst
Well lockdown is well underway. so was thinking of the next upgrades that could be done.
Ideally would like a full length black roof rack.
As per other post will upgrade headlight loom plus fit some better bulbs front.
Plus will fit some rear work lights, ideally off the rack.
Plus an upgraded reversing light.
If funds really permit a webasto coolant heater would be nice, will mean no static running when shower is needed!
for the now, its a strip out of the shooting kit and a repack with the camping kit - i want to be ready to go when lockdown lifts!
Rear cleared out and 'tea' shelving back in. i forgot how big it was back there! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #876929 7th Jan 2021 8:04pm
jst
130 is still providing Stirling service, out on log duty last few days.
Have a boomslang loom plus some rear spot lights to add now, along with brighter headlight bulbs.
Big purchase after much consideration, patriot 3.5m black rack enroute, have asked them to space the feet sufficiently to fit in the front runner table. On fact space for two! Due in a week or so. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #878321 13th Jan 2021 8:39pm
L110CDL
The roof rack will make it look very different again, will look proper Thumbs Up Clayton.
Keeper.
Post #878336 13th Jan 2021 8:57pm
jst
Patriot rack made to order due end of the week! will then need to find time to fit it!
Have some rear spots to add to the rack so need to get the wiring sorted for that off a dash switch (thank you TJ101)
Fitted an interior light under the gull wing door to aid cooking of an evening.
Even now have the perspex to fit under the roof tent to fill the gap between roof tent and awning, something thats been on the list since talking about it 18mths ago!
Looking forward to fitting the rack but not looking forward to cleaning it first which should really be done! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #880989 26th Jan 2021 10:46am
jst
Racks arrived! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #883044 3rd Feb 2021 11:05pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Looking forward to seeing it !
I’ve just put a deposit down on a 130 so will avidly be watching this thread.
I’ve got a Hannibal on my 110dc which clearly won’t fit my 130 but it looks as though Tembo make a near identical rack. Did you ever look at them or were you set on Patriot ? https://www.instagram.com/hustynminepark/
Post #883046 3rd Feb 2021 11:31pm
jst
I have a hannibal on my 90, works well. But to low to get table under.
Tembo one, sits a fair bit higher from memory and slats run across? I think from research I had a height issue, too high this time with tembo. They also never replied to enquiries.
110 usw rack will fit, check my other pics.
Patriot but default almost, they rang back on an enquiry and built to order with leg spacing. I know product is good for test of time so went with gut on it. More £££ but they were more accommodating and flexible on changing dims to suit my needs. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #883072 4th Feb 2021 8:37am
jst
Well i have had the rack for a week, just dont seem to have time to spend sorting it. Starting to get there now.
Its a Patriot rack made to order for 130 with a double cab front support and an adpated (900mm spacing) rear double feet back. Table fits between the feet supports so needed to be wider than their standard set up.
Table supports now fitted. Roof tent studs fitted. Just the awning mount to sort and the Perspex for the rear (rain guard for the gap between awning and roof)
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #884050 8th Feb 2021 10:07pm
L110CDL
That is a very nice rack there James and glad your sorting it out Thumbs Up Clayton.
Keeper.
Post #884053 8th Feb 2021 10:17pm
TJ101
Found the clear sheeting a excellent mod, i used AXGARD Polycarbonate
keep the rain out between the awning and rack
 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #884087 9th Feb 2021 8:33am
jst
Good idea that!
have you fitted RT and awning to your new rack yet? pics its hard to tell but i guess thats the old one? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #884262 9th Feb 2021 8:16pm
TJ101
Shocked
Rack looks Black to me in picture ? Yes, all fitted to new black rack California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #884269 9th Feb 2021 8:42pm
jst
i just thought it was a dark day reflecting the light! good thats it all on, so now to use it! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #884561 10th Feb 2021 7:52pm
jst
Well its on and outside!
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #886740 20th Feb 2021 1:46pm
