Home > My Defender > a 130 itch
Page 17 of 21 <123 ... 161718 192021>
camelman
Looking 👍
Post #886743 20th Feb 2021 1:48pm
JOW240725
Shame you didn't get an extended rack over the bonnet, looks a bit short! Whistle Shocked Laughing
Looks great!! Thumbs Up James
Instagram @suffolk_rovers
Post #886764 20th Feb 2021 3:08pm
jst
Well I have measured up, two roof tents would go easily, could of had two maggis if I had gone over bonnet! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #887665 25th Feb 2021 8:41am
jst
Its taken a while but after fitting rack a while back the roof tent is now on, plus the skylight! - ( perspex to stop raining coming between tent/awning) i have even managed to sort the wiring for the solar and roof tent light with bulkhead fittings and a connector for when the roof tent is removed. that for me is good going - even more so as they work as intended!
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #890582 10th Mar 2021 9:02pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Looking great , that really is a vast roof rack !
My 130 arrives on Friday (gales allowing) .
I’ll be in touch with Patriot as soon as it arrives .
I’ll be selling the double cab as soon as I’ve stripped it of all the upgrades as I can’t believe someone would pay for them on top of what the trucks worth https://www.instagram.com/hustynminepark/
Post #890591 10th Mar 2021 9:29pm
jst
Rack was a special order, with rear legs width centres specified to fit a table inbetween from Patriot. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #890842 11th Mar 2021 9:12pm
jst
I suppose I should get a black rooftent
..... Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #893723 24th Mar 2021 9:13pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
Or some black paint 😉😉
Post #893728 24th Mar 2021 9:21pm
camelman
or zome zebra stripes Whistle
Post #893730 24th Mar 2021 9:24pm
JOW240725
Or white rims!! Laughing James
Post #893735 24th Mar 2021 9:59pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Just some black vinyl. Easy to do yourself for little money?
Post #893754 25th Mar 2021 6:27am
jst
theres an idea!
maybe i will just take it off!
Update on the shower system. i bought a larger heat exchanger this time (than the one in my 110) hoping it would work off engine warm up from cold on tickover. It sort of does but takes away too much heat from the engine - typical!
110 one is plumbed in straight after a webasto coolant heater.
think its time to add a webasto coolant heater to the 130.
anyone ordered one from Russia....? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #893796 25th Mar 2021 9:59am
jst
Busy last two days
Changed the vcv, what a horrible job, cured the rough starting and idle but only ran for 20s then stopped. Restarted straight away, first flick, and stopped after 20s again.
Removed new vcv, (denso), fitted a 2nd new one (pj jones) and works a treat.
Also fitted a webasto evo 5 water heater. Just under £600 new with full fitting kit. Took 5 days from russia.
No air intake filter or exhaust silencer but otherwise complete.
Slight hiccup with red and black wire needing a home, see other thread, but otherwise now fitted with direct feed to shower heat exchanger before it circulates rest of engine.
No more cold starts and no idling to have a hot shower now!
Dropped the tank in the end to fit the pickup into top of tank. Not convinced o space on a hicap around the filler.
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #899576 22nd Apr 2021 3:44pm
jst
typical, another camping weekend coming up and whats it going to do - RAIN and blow like anything. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #904150 20th May 2021 7:54pm
jst
Well we got a bit wet but it was worth it. Nice time of year to be out normally!
found an interesting tree....s
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #905006 25th May 2021 7:37pm
