Home > My Defender > a 130 itch
Page 15 of 21 <123 ... 141516 ... 192021>
benspray
United Kingdom 2006 Defender 130 Td5 HCPU Chawton White
Hi James
Yep, so I have the southdown guard with the towing attachment and recovery eye off my 110, and I currently have the non-adjustable style towpack on my 130, thinking about fitting the southdown unit on the 130 to gain a bit of departure angle, but not sure how best to extend. I considered finding someone to cut off and weld on the extension piece from the standard 130 tow pack but sure it will bring loads of liability issues, I also wonder if having something adjustable on a dixon bate style slider on the southdown guard may be better - potentially a lot of weight to try and remove/refit as needed then though?!
I don't have a good photo at the moment but its this style:
Ben
Post #867197 13th Nov 2020 10:30pm
jst
Your suggestion is nearly what I have done. Had the work done by a professional welder. I used the standard 130 bracket, as per pic., he did a cad drawing for side pieces drawn up to pick up on Southtown holes for hitch, added a 60mm further spacer then welded these sides to the back of the original hitch. The extra 60mm was because i wanted the tailgate to miss a trailer jockey wheel.
You could cut the top off the original 130 hitch and lower brackets for arms and bolt it to your existing Southdown hitch.? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #867977 17th Nov 2020 9:25pm
benspray
Cheers James
I did wonder if the holes would line up and like you say just cut the original plate down and bolt it on, I'll have to measure up and see Smile
130 is in for an MOT and some wheel bearings at the mo, so once it's back I'll have a look đź‘Ť
Ben
Post #867994 17th Nov 2020 11:22pm
jst
Here is mine
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #868091 18th Nov 2020 12:00pm
jst
There is 60mm extra qbetween top mounting hole and original rear plate of 130 std hitch.
Its also dropped a fraction to allow for HD suspension. As you can see I got it slightly wrong as ball now on top hole set! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #868092 18th Nov 2020 12:03pm
benspray
Thanks James looks good Smile
Should get mine back later today so will start measuring Smile
Post #868093 18th Nov 2020 12:14pm
jst
How did you get on? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #869627 25th Nov 2020 9:14pm
jst
Just to follow on from my 1.3 T box post, really pleased with it. quite a few miles under its belt and a fair few towing, working very very well with my 130 and has taken out a great deal of backlash from the previous LT230. granted an element may be the replacement intermediate shaft (came from Ashcrofts along with both boxes) and could be from gearbox change but there wasnt a great deal of noticeable wear on either outgoing items. Just happy to have it up and running, pulling well and doing what is was made for. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #869670 26th Nov 2020 9:25am
benspray
jst wrote:
How did you get on?
Sorry missed this Wink
Not had a chance yet, MOT needed discs and bearings, exhaust and fuel pressure release valve so still sorting although nearly there going over to Demand Engineering tomorrow for the exhaust then retest early next week Wink
Post #869685 26th Nov 2020 11:16am
jst
Hope all that went well.
130 currently doing its job well.
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #873371 16th Dec 2020 9:56pm
jst
Lovely weekend camping in mid Devon this weekend, was a bit wet Friday! Went in minimalistic mode!
Had to cut our way into camp too!
It was nice to be out, some wet sections there too, not the 130!
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #873925 20th Dec 2020 9:26pm
Kizmax
Ireland 1993 Defender 130 200 Tdi HCPU Corris Grey
Hi jst
Excellent write up looking forward to picking through it as I start into my 130
Justin
Post #874094 21st Dec 2020 10:01pm
jst
Its been a real success for me so far, i was worried it would be too much to use day to day but is working well. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #874097 21st Dec 2020 10:05pm
jst
So, having had this painted back around end of lockdown 1, I haven't washed it yet, so pleased to have fitted the Gwyn Lewis mud shields
Front of rear wheel inside arch
And the bit that's protected by the sheild
Rear of rear wheel arch
And the protected crossmember
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #874820 27th Dec 2020 4:54pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
They look as though they’ve been very effective , I’ve been thinking about those for a while ! https://www.instagram.com/hustynminepark/
Post #874831 27th Dec 2020 5:33pm
