![]() | Home > My Defender > a 130 itch |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8176 ![]() ![]() ![]() |
So mud outweighed rust, one mudflap off. Gwyn Lewis to the rescue. Mounted them high to cover the end of the side sills. hopefully they are still long enough. Should stop crud going up the side.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Making a start.
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1165 ![]() ![]() ![]() |
Did the same Gwyn Lewis from flap shield and brackets. Beautiful natural fit. Looks factory and provides a whole bunch of protection! Nice piece of kit.
Bye bye Puma
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Well that was fun. What a time consuming job removing a 2.4 compared to most other lr engines.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17620 ![]() ![]() ![]() |
It's a big lump when it's in one piece!
Sure is. Easier though if crane or lift is upto the job I think Cheers
It's always nicer putting things together.
Jon w Member Since: 22 Dec 2015 Location: North East Wales Posts: 217 ![]() ![]() ![]() |
You did well getting it out all in 1 lump. with the angles etc and getting it over the front crossmember. When I did the 200tdi it was hard enough to keep the transfer box up off the floor and sump up and over the front crossmember.
have done the last few like that, a long reach engine crane and ratchet strap to bring t box up one its been brought fwd a little. is quite heavy though Cheers
Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 177 ![]() ![]() |
Cracking on I see.
![]() Wish I had the space, things take so much longer when your fighting for room Be GB and TB in 1st then bolt it together in situ ![]() |
half the 130 was out the garage to lift the lumps in! saw your thread on garage not been long enough for you 90, think how a 130 goes!
cooling pack in in now and gbox cooler sorted. waiting on last ac pipe and fuel fittngs then some wiring to do. hoping engine turn end of this week, Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Getting there....
Well it's been a bit love hate at times but agro will be worth it.
