Home > My Defender > An Anorak's Utility Station Wagon
Page 43 of 57 <123 ... 424344 ... 555657>
L110CDL
Good news there with the clunk gone away and you sure do have good mechanic's looking after your 110 Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #872209 9th Dec 2020 8:40pm
I had a rare trip out today and felt the need to record for posterity that it had moved from my drive Rolling Eyes
It was a bit sluggish turning over too, so need to connect it to a charger again. Darren
Post #877308 9th Jan 2021 5:02pm
Towing Electrics - Part 2
The current need to keep connecting my Land Rover to a battery charger has finally pushed me to get my finger out and finish my towing electrics!
It was always my intention to fit a 13 pin socket in the hole in the rear cross member that’s designed for the purpose and to make my life easy, I began with a pre-wired socket:
This will be fitted with M5 steel rivnuts to avoid bi-metallic corrosion, which was also an excuse to break out my rivnut tool that was actually bought for this job. I’ve had a more traditional hand riveter-type tool for years but the end-on design of this one makes it much easier to use in the confined space of the towing socket recess.
The first job was to mask up the area to prevent any damage to the paint. I then positioned the new socket, marked the three fixing holes and drilled them out to 7mm to receive the rivnuts:
I removed the tape from the inner area and gave the new holes a squirt of Dinitrol before setting the rivnuts. I also cleaned out the swarf from the drilling as I don’t want that rusting away in there.
And with all of the rivnuts in place:
I replaced the mild steel M5 bolts that came with the socket with some stainless Torx head bolts and gave each of them a coating of anti-seize paste before fitting:
And with the socket fixed in place:
The cable bundle was fed through the chassis and into the junction box that I installed when I fitted the receiver hitch back in September ’19 (I've been busy, ok?):
Connecting up was straightforward with the use of the conversion chart that I’d created when I completed the first part of this job:
And all closed up:
Finally, a wider view of the finished socket. This is the best place for the towing electrics as it keeps them out of the way and well protected:
It's now ready for me to connect my CTEK charger as soon as a 13 pin adapter arrives from the site shop! Darren
Post #879215 17th Jan 2021 9:57pm
camelman
Have you thought about a solar panel to keep your battery charged?
I'm going to stick a couple on top of the roof tent.
Post #879218 17th Jan 2021 10:04pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Nice job that Thumbs Up
Post #879231 17th Jan 2021 10:56pm
Thanks Badger Smile Darren
Post #879250 18th Jan 2021 8:12am
Not really, to be honest. I don't particularly want a permanently fixed solar panel, nor the hassle of demounting it every time I want to use the vehicle. Plus the CTEK that I'm planning for can be easily swapped between my 110 and my wife's Discovery, which is parked alongside and has the same towing electrics. Darren
Post #879252 18th Jan 2021 8:20am
L110CDL
Great work and execution as ever Darren Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #879407 18th Jan 2021 9:34pm
Thanks Clayton Thumbs Up Darren
Post #879422 18th Jan 2021 10:18pm
Windscreen
Following the collection of a large chip (I think acorn related!) and impending MOT, I had a new windscreen fitted this morning. No pictures unfortunately, due to Covid restrictions in the workshop. Still, I was pleased to see that the replacement is a Pilkington unit.
Notwithstanding the chip, a new windscreen is a lovely thing as they're sooo clear Laughing Darren
Post #885838 16th Feb 2021 11:44am
Badger110
It's like putting on a fresh pair of socks Laughing
Did you get to the bottom of that leak in the passenger footwell?
Post #885898 16th Feb 2021 3:45pm
Heh, heh, exactly Laughing
No, not yet tackled the leak - the weather has been too miserable Rolling Eyes Darren
Post #885921 16th Feb 2021 5:15pm
Halogen Headlight Bulbs
A bit of a sad day today, as I removed my excellent CHEAPSKATE LED headlight bulbs and returned them back to halogen. The legality of these bulbs was always a bit ambiguous, which I was happy to accept as they'd passed last year's MOT without question. However, a recent change to the MOT SECTION 4.1.4 has now specifically made the fitting of LED bulbs in existing headlights to be a fail, so they had to go.
When I fitted the LED bulbs DETAILED HERE, I drilled two holes in each wheel arch liner for a cable tie to secure the LED driver gubbins. With that removed, I sealed the holes with duct tape to keep road crud out:
With one side done, the difference is, well, obvious:
I also changed the sidelight bulbs as whilst not strictly required, they'd look odd as white LED's.
The bulbs I'm using are these uprated ones from Philips:
I've used various incarnations of their uprated bulbs before, so I'm reasonably confident that these will perform well. Whether they'll be as good as the LED's is, of course, a moot point Rolling Eyes Darren
Post #886208 17th Feb 2021 9:21pm
L110CDL
It is sad when you have to do this as the LED's are far much better but i just wish that someone / firm would make a proper LED oem replacement headlight for a defender Rolling Eyes 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #886212 17th Feb 2021 9:28pm
kenzle8a
I bite the bullet and bought truck lites for mine. While i could find more holes in the law than Swiss cheese, sometimes it’s easier to pay extra.
Post #886217 17th Feb 2021 9:47pm
