![]() | Home > My Defender > 1988 Shire Blue Landrover 90 Restoration |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2693 ![]() ![]() |
I can understand your attachment to the vehicle and it’s originality, I have had my 90 since just after I started driving and am quite fond of the Tdi despite its mileage and the fact that there are other much better and newer engines that could be retro-fitted. Thanks for the info on painting, you’ve achieved a good finish. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3475 ![]() ![]() ![]() |
A little update with a picture of 2 half engines. I trust that eventually I will have one good engine. Lots of cleaning needed... and the list of engine parts to buy is growing...but will get there.
![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Just an update with some cleaning progress around the engine bay.
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
![]() ![]() ![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Thank you James.
![]() Most of the paint on front part of the chassis is original. Had painted the dumb iron and the front most cross member at some point in its life, as those were not protected by the 19J blow by (given the speed it could go at) ![]() The heat shield on the bulkhead is original as well, and mostly unmarked. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
A short update..
Apart from wiping and wiping old waxes, and oily dust build up, the bulkhead to chassis harness has been disconnected.... which leaves the only obvious choice... that is to take out the bulkhead. Was not in the plan, but will make painting the bulkhead much easier and better. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Well if a job is worth doing....
![]() It'll be worth it! ![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Yeah, Thats what I thought. I do not want to put everything back together and then regret something that I missed or skipped intentionally. The problem is that I am still turning screws anti clockwise. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
I really do not know where to stop...
Bulkhead has been almost stripped. Still need some careful peeling of the heat shield as want to re use them. ![]() Click image to enlarge I am not sure if I should just paint it, or have it galvanized and then painted. I do not think the galvanizing is able to go in between areas where it is double skinned. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10866 ![]() ![]() |
Can't help you with to or not to galvanise the bulkhead but you should be able to stop taking it apart when there is no more bits to take apart so keep going as your doing an awesome job on the 90
Well said Clayton 😂. Luckily I do not have a spot weld driller. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Removed the panhard rod bracket from the chassis. Where the bush locates was quite worn. Actually the pic shows the better side. Other side was worn by at least 0.5mm.
Checked the prices for a new one... ![]() So worth a try filling with weld and re grind. Jury rigged a grinding system and worked really well. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3690 ![]() ![]() ![]() |
Quick escape to the workshop.. I knew that I had the dim dip controller PRC6336 disconnected long time ago. IIRC, the problem then was that the dip would stay on, even with the light switch off. Since had little time, and did not feel like getting dirty, turned my attention to the electronics
![]() Turns out that the little green transistors had shorted, and hence the dip were getting full voltage all the time. I do not have any equivalent transistors (but have some mosfets which would also work), but have tested the control circuit with some cheap D882 transistors that I had lying around. This confirmed that the control circuit works (works on a PWM). Output voltage was about 6V. It pulses, hence the interference in the radio when the side lights are on. ![]() PRC6336 are quite some money to buy new, so happy that they are fixable for a Pound. ![]() Click image to enlarge ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
