Home > My Defender > Grafty's Td5 90
Page 119 of 124 <123 ... 118119120 ... 122123124>
Procta
grafty99 wrote:
Just more pictures today. The RRC is currently in the workshop (nearly finished) then the 90 will be going in for webasto install and mounting the clock. Until then.....
this needs white lettering on its tyres Whistle Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #871234 4th Dec 2020 5:45am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Smart work as usual Thumbs Up
The more I see people with cab/block heaters, the more I'm tempted, especially now we're seeing the cold weather set in 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #871262 4th Dec 2020 10:16am
grafty99
They're fantastic - our L322 has one and that's what convinced me I needed on on the 90 Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #871278 4th Dec 2020 12:33pm
grafty99
Progress has been made on the webasto install today. Unfortunately the electronics haven't arrived so things like remote phone control and the in dash controller aren't going to happen this weekend.
So far I've plumbed it into the coolant circuit (priority to cabin heat) and wired in power with connectors supplied by Martin Bow down
The passenger side of the engine bay is now looking rather full!
Tomorrow I'll drop the fuel tank and fit the feed pipe and fuel pump. All that will be left after that is the controller and exhaust Cool 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #871466 5th Dec 2020 7:25pm
Rashers
Another very neat install Thumbs Up
Post #871491 5th Dec 2020 8:53pm
Zed
Great work George, and just in time for winter. WARNING.
Post #871506 5th Dec 2020 10:21pm
grafty99
The Webasto is now fully installed and finished!
There are currently 4 ways it can operate.
1) Start the engine and the Webasto turns on until the coolant reaches 85°C. After this it enters standby mode and if the coolant temperature drops below 75°C (if sitting in traffic with the heater going for example) then it will fire back up until the coolant reaches 85°C again (not ideal I know, as the thermostat starts to open at 82°C but this will only be a problem in the traffic scenario which is a rare occurrence for me)
2) I've installed a temporary button in the centre dash to operate the Webasto if you were sat in the defender waiting for someone for example and got a bit cold. It would give you a 20 minute shot of heat then turn off - round button above stereo).
3) Call the GSM relay from a mobile - the relay hangs up immediately and activates the Webasto for 20 minutes. Perfect if you were out for dinner for example and the defender was parked a 5 minute walk away from the restaurant. Call the GSM relay after you ask for the bill and return to a toasty cabin Cool
4) I have installed a hidden winter/summer/service switch that deactivates the webasto completely but leaves the GSM relay to control the cabin fans. This way on a hot day I can call the defender and it will start the fresh air fan to cool the interior for 20 minutes before you get in Thumbs Up
There are some refinements I'm considering but all it all it works a treat Mr. Green 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #875363 30th Dec 2020 11:07pm
Co1
Superb set up Grafty, nice work 👍
Post #875384 31st Dec 2020 7:45am
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
It sounds like a good set up Thumbs Up
Post #875390 31st Dec 2020 8:48am
A remote start Webasto is fantastic. Many years ago I had one fitted to a 300tdi Discovery with the Telestart option, which was a quite large key fob that had a range of about 100m. It was great to be able to sit in my, at the time, fourth floor office and fire it up although it did startle a few people as it sounded like a small jet engine Laughing Darren
Post #875394 31st Dec 2020 8:58am
grafty99
Thanks chaps! Bow down
Mine has a silencer so is actually quite quiet, although for the first test run I did on the bench it didn't have the silencer on and, like you say, sounded like a small jet starting up Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #875399 31st Dec 2020 9:29am
Martin
Site Admin
Well done George, nice setup and pleased to be able to help supply some of the bits Very Happy  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #875407 31st Dec 2020 9:49am
grafty99
Thanks Martin, the connectors you supplied made the job 100x easier that's for sure! Unfortunately, as you predicted, pin 8 isn't configured on D3/4 heaters Crying or Very sad was worth a try though! 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #875410 31st Dec 2020 10:12am
bankz5152
Very nice work!!
Have you had any issues thus far with the fans setting your alarm off?
I found with my derv fan heater it 70% sets the alarm off, likely due to the volumetric sensor going off. Instagram @defender_ventures
Empire Tuning - Agent
Post #875411 31st Dec 2020 10:14am
grafty99
It hasn't yet, you can adjust the gain on the volumetric sensor in the nanocom, might be worth turning it down a touch Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #875416 31st Dec 2020 10:31am
