Home > In Car Electronics > Pioneer releasing the first single-DIN unit with Carplay
Page 10 of 11 <123 ... 91011>
TriniDaddy
2008 Defender 110 Puma 2.4 XS CSW Arles Blue
Hi guys.
Do the single din screens block the air vents when the screen is out? In addition to the hazard button. I'm thinking there'll be some type of condensation to the back of the screen that may drip down to the unit.
On the fence deciding if to do the facia conversion.
Post #874881 28th Dec 2020 2:10am
That's not a problem I've ever noticed, the screen does not come up that far (I can still see the clock while driving).
Post #874886 28th Dec 2020 7:54am
Vitesse
Hi. I fitted mine in Sept 17 and eventually re located the 3 hidden switches to a MUD pod on the dash top. It is true you can still sort of reach them behind the screen but it is a bit awkward. I was also wanting to mount an oil temp gauge so it worked for me. I also converted to Disco 2 Hazard switch and wiring in order to use the normal size switch mounts in the pod. Thumbs Up 2015 90 XS Santorini Black
Post #875016 29th Dec 2020 12:52pm
TheWarden
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Just picked up the AVH-Z7200DAB on Amazon - it crops up every now and again - I was checking daily and got it for £430 so very happy. Now the fun of fitting it 2013 Aintree Green 110 Station Wagon SX
Post #875210 30th Dec 2020 2:59pm
That’s a good deal, I got mine from there too but paid about £520.
It’s a great unit, I’m very pleased with it. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #875254 30th Dec 2020 5:14pm
TriniDaddy
Please put some pics up when it's in.
I'm seeing that it plays with the screen in so I'll only pop it out for maps and remote F1 viewing.
Post #875300 30th Dec 2020 7:37pm
r1ch3d
Australia
ak34 wrote:
Avelingporter wrote:
Does anyone know of a single din CarPlay unit that does not have a pop out screen. Ie like the £1500 Porsche pccm branded unit, but without the Porsche price!!??
This week installed Sony XAV-AX8050D. It has fixed screen. Got in on Amazon Prime day for 399 EUR. Probably had to remove screen for yearly inspection or relocate hazard warning button. But all top buttons are reachable.
Love your work AK34! I'd love to know how you mounted the single din securely in the dash? I have the Sony XAV-AV8000 and the instructions say to use the manufacturers (read Land Rover's) mounting brackets and not the sleeve / cage. But for the life of me I cant find anything or anyone that makes or sells these things. Otherwise I can definitely see this shiny new unit rotating down and smashing onto the gear stick
Thanks in advance
Rich
Post #876348 4th Jan 2021 11:52pm
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Rich, I've got the same Sony unit installed and just used the supplied cage, as per a single din - it's been in for 6 months or so and doesn't move / feel insecure at all. Certainly no brackets etc that are different to standard.
Best,
A 110 Tdci Double Cab
Post #876382 5th Jan 2021 11:53am
r1ch3d
Australia
Thanks Alex
Mine wasn't shipped with a cage, so I'll jump on eBay and buy a universal single din sony cage / sleeve and give that a whirl
Post #876534 5th Jan 2021 11:18pm
walfy
Finally fitted mine yesterday, but the DAB antenna is a bit of a strange one.
It has the long cable with a block at the end and a small strange shaped rigid plastic piece. I get that they have to go together but where has everyone fitted it?
It says it's not good with heated screens, but can I mount it horizontally in an alpine light window?
Or is there an easier solution. Without spending the world? 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #885855 16th Feb 2021 1:07pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Post #885857 16th Feb 2021 1:39pm
walfy
meeerrrk wrote:
Brian, I followed your advice and since grounding the handbrake wire (it must be grounded when the unit is powered up, not after) then it works - strange but good!
Anyway using the unit all day today and I�m so chuffed with it - fantastic / ticks all the boxes Thumbs Up
Do you have it permanently earthed out? This is the last job to sort I think on my instal 110 D250 SE HT
110 USW SOLD
Post #886111 17th Feb 2021 12:59pm
ak34
Latvia 2008 Defender 110 Puma 2.4 HT Aintree Green
Did not want to change the dash for 2-DIN screen and 1-DIN version I installed in Puma would be too low and too close to gear stick in 300tdi. But wanted to get CarPlay in this Defender as well. Therfore ordered wireless Apple CarPlay screen from Aliexpress for 180 EUR. Unfortunatelly it is no longer available, but there should be similar ones if somone is interested. https://www.aliexpress.com/item/1005002539...4c4drT0ZKS
So far it looks good. The price was very good and if it lives for couple of years I will be happy. Then will change to something. I like that screen is quite high. Probably have to do something with wiring later
Post #907264 10th Jun 2021 3:40pm
BrickBox
stephan123 wrote:
Just fitted to my car. Very pleased with the result. Added bonus that I can still get my fingers behind the screen to access covered buttons Very Happy
Can someone confirm what head unit/model this is, please? This looks perfect. 2008 2.4 110 Utility Station Wagon XS.
Post #980394 29th Jan 2023 7:41pm
stephan123
Pioneer AVH-Z7200
Post #981052 2nd Feb 2023 11:43pm
