Home > In Car Electronics > Pioneer releasing the first single-DIN unit with Carplay |
TriniDaddy Member Since: 23 Nov 2020 Location: 10.57422, -61.28906 Posts: 27 |
Hi guys.
Do the single din screens block the air vents when the screen is out? In addition to the hazard button. I'm thinking there'll be some type of condensation to the back of the screen that may drip down to the unit. On the fence deciding if to do the facia conversion. |
28th Dec 2020 2:10am |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 381 |
Hi. I fitted mine in Sept 17 and eventually re located the 3 hidden switches to a MUD pod on the dash top. It is true you can still sort of reach them behind the screen but it is a bit awkward. I was also wanting to mount an oil temp gauge so it worked for me. I also converted to Disco 2 Hazard switch and wiring in order to use the normal size switch mounts in the pod. 2015 90 XS Santorini Black
29th Dec 2020 12:52pm |
TheWarden Member Since: 25 Feb 2013 Location: Southampton Posts: 179 |
Just picked up the AVH-Z7200DAB on Amazon - it crops up every now and again - I was checking daily and got it for £430 so very happy. Now the fun of fitting it 2013 Aintree Green 110 Station Wagon SX
30th Dec 2020 2:59pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20329 |
That’s a good deal, I got mine from there too but paid about £520.
It’s a great unit, I’m very pleased with it. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
30th Dec 2020 5:14pm |
Please put some pics up when it's in. I'm seeing that it plays with the screen in so I'll only pop it out for maps and remote F1 viewing. |
30th Dec 2020 7:37pm |
r1ch3d Member Since: 23 Dec 2020 Location: Victoria Posts: 4 |
Love your work AK34! I'd love to know how you mounted the single din securely in the dash? I have the Sony XAV-AV8000 and the instructions say to use the manufacturers (read Land Rover's) mounting brackets and not the sleeve / cage. But for the life of me I cant find anything or anyone that makes or sells these things. Otherwise I can definitely see this shiny new unit rotating down and smashing onto the gear stick Thanks in advance Rich |
4th Jan 2021 11:52pm |
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 |
Rich, I've got the same Sony unit installed and just used the supplied cage, as per a single din - it's been in for 6 months or so and doesn't move / feel insecure at all. Certainly no brackets etc that are different to standard.
Best, A 110 Tdci Double Cab |
5th Jan 2021 11:53am |
Thanks Alex
Mine wasn't shipped with a cage, so I'll jump on eBay and buy a universal single din sony cage / sleeve and give that a whirl |
5th Jan 2021 11:18pm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2658 |
Finally fitted mine yesterday, but the DAB antenna is a bit of a strange one.
It has the long cable with a block at the end and a small strange shaped rigid plastic piece. I get that they have to go together but where has everyone fitted it? It says it's not good with heated screens, but can I mount it horizontally in an alpine light window? Or is there an easier solution. Without spending the world? 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
16th Feb 2021 1:07pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2037 |
How about using one of these? :
https://www.dabonwheels.co.uk/product/aerial-converter-splitter/ |
16th Feb 2021 1:39pm |
Do you have it permanently earthed out? This is the last job to sort I think on my instal 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
17th Feb 2021 12:59pm |
ak34 Member Since: 23 Apr 2015 Location: Riga Posts: 15 |
Did not want to change the dash for 2-DIN screen and 1-DIN version I installed in Puma would be too low and too close to gear stick in 300tdi. But wanted to get CarPlay in this Defender as well. Therfore ordered wireless Apple CarPlay screen from Aliexpress for 180 EUR. Unfortunatelly it is no longer available, but there should be similar ones if somone is interested. https://www.aliexpress.com/item/1005002539...4c4drT0ZKS
So far it looks good. The price was very good and if it lives for couple of years I will be happy. Then will change to something. I like that screen is quite high. Probably have to do something with wiring later Click image to enlarge |
10th Jun 2021 3:40pm |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 808 |
Can someone confirm what head unit/model this is, please? This looks perfect. 2008 2.4 110 Utility Station Wagon XS. |
29th Jan 2023 7:41pm |
stephan123 Member Since: 18 Mar 2015 Location: London Posts: 282 |
Pioneer AVH-Z7200
2nd Feb 2023 11:43pm |
