Home > Maintenance & Modifications > Slick shift ? |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3643 |
loads of threads on here regards the options and peoples views, here's 2
https://www.defender2.net/forum/topic74564...lick+shift https://www.defender2.net/forum/topic66052...lick+shift DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
19th Nov 2020 7:55pm |
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 |
Many thanks , found what I needed
19th Nov 2020 10:25pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2645 |
Fitted one about 3 years ago - what a difference in the gear chages.
DO IT!!! -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
20th Nov 2020 6:59am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17439 |
I can't see how having a shorter throw would achieve that, myself. |
20th Nov 2020 8:06am |
the one major improvement over the OEM unit is that it feels & operates like a 'gated' unit - so you're never hunting around for the correct gear.
everything also shifts with minimal input - so now you can change gears with your fingers instead of having to use your whole arm. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
20th Nov 2020 8:13am |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
Love mine, fitted 40000 Km ago!
Slick Shift is not the right name. It feels more mechanical and precise. Smoother, it isn’t. It encourages you to drive more smoothly. 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT´s, Recaro CS´s, anorak, wellingtons |
20th Nov 2020 12:46pm |
