Home > My Defender > What Did You Do In Your Defender Today |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2900 |
I think the gloss black arches look best with 16” gloss black sawtooths. My 110 came with the factory black pack but when I added the twisted wheels I had them colour coded. Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
13th Nov 2020 6:12pm |
Then they will look lovely Andy
13th Nov 2020 7:24pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5855 |
Yesterday removed the front winch bumper pending the 110 in for paint the week after next.
Took the chance to take the winch, the spot lights off the bumper so they can all get a much needed coat of paint. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
14th Nov 2020 6:25pm |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 823 |
Click image to enlarge Treated it to a origional Land Rover fuel filter. Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
15th Nov 2020 12:37pm |
Ordered new fixed windows to replace the rear sliding windows in the 110. 1999 Defender TD5 110
18th Nov 2020 1:24pm |
Broonster Member Since: 14 Dec 2019 Location: West Lothian Posts: 23 |
Interesting, I’ve been looking at those. Looks great! How was the install? And have you just wired up to reverse or do you have a separate switch? ‘08 Defender 90 Hardtop |
19th Nov 2020 10:18pm |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1000 |
Took both the 90 and 110 in for their MOT’s both passed just 2 small advisories on the 110 new rear prop uj needed and some rear brake pipe needs replacement due to corrosion. Already knew uj was likely to need changing so pleased with not much else Andy
Defender 90 Defender 110 XS Cupra 290 |
19th Nov 2020 10:31pm |
Collected the newly blasted and powder coated bonnet and wing chequer plate from the blasters/coaters. The bonnet CP has now got a slight bow in it looks like I will have to try and remove said bow. 1999 Defender TD5 110
20th Nov 2020 3:44pm |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
No i wired it using the constant live from behind the drivers side speaker panel, took the wire over the back door and back down. ive then got 2 ground wires for it, one is on the speaker panel directly behind it with a switch and the other goes to the dash with a switch so i can turn it on from the dash or the back of the car. Fitting was a bit of a pain as my landy has always had a dent where the previous owner reversed into something and hit the reverse and no plate light. Part of the reason i bought this was to cover it up (good excuse). So i tried mounting it straight to the body but in was noticibly wonky pointing outwards so i took the old number plate light plinth and cut it diagonally into a little wedge about 2-7mm thick and then it was flat It was quite useful having it off the body 5mm in the end as i could run the cable into the fatter part of the wedge and into the car which looks neater than having the cable showing |
20th Nov 2020 4:03pm |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 932 |
Recovered my headlining
Click image to enlarge And bought a temp garage for the 110 to go in soni can paint it |
20th Nov 2020 4:05pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17458 |
That headlining is looking good, outstanding job!
I need to do my Disco2 but I keep hesitating in case it turns out to be a disaster. |
20th Nov 2020 5:05pm |
I used 4 way stretch carpet from Ebay. 43 quid for a 5x2m roll and 5 cans of spray adhesive.
Quick YouTube review and then got stuck in. Very easy if a little messy with over spray from the glue. https://www.ebay.co.uk/itm/320965717945 |
20th Nov 2020 5:39pm |
However did we manage before YouTube?
20th Nov 2020 6:04pm |
Is that a random thought, or in response to something in particular?
20th Nov 2020 7:01pm |
