Page 1296 of 1382 <123 ... 129512961297 ... 138013811382>
mcma1
I think the gloss black arches look best with 16” gloss black sawtooths. My 110 came with the factory black pack but when I added the twisted wheels I had them colour coded. Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #867140 13th Nov 2020 6:12pm
CarMan
Oh no, as it happens I have 16” black sawtooths with no plans to change them Confused Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #867151 13th Nov 2020 7:20pm
mcma1
Post #867153 13th Nov 2020 7:24pm
excossack
Yesterday removed the front winch bumper pending the 110 in for paint the week after next.
Took the chance to take the winch, the spot lights off the bumper so they can all get a much needed coat of paint. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #867392 14th Nov 2020 6:25pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Treated it to a origional Land Rover fuel filter. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #867505 15th Nov 2020 12:37pm
excossack
Ordered new fixed windows to replace the rear sliding windows in the 110. 1999 Defender TD5 110
Regards
John M0VAZ
Post #868111 18th Nov 2020 1:24pm
Broonster
Scotland 2008 Defender 90 Puma 2.4 HT Keswick Green
LandymanStefan wrote:
Uproar 4x4 number plate rear work light.
Interesting, I’ve been looking at those. Looks great!
How was the install? And have you just wired up to reverse or do you have a separate switch? ‘08 Defender 90 Hardtop
Post #868468 19th Nov 2020 10:18pm
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
Took both the 90 and 110 in for their MOT’s both passed just 2 small advisories on the 110 new rear prop uj needed and some rear brake pipe needs replacement due to corrosion. Already knew uj was likely to need changing so pleased with not much else Very Happy Andy
Defender 90
Defender 110 XS
Cupra 290
Post #868471 19th Nov 2020 10:31pm
excossack
Collected the newly blasted and powder coated bonnet and wing chequer plate from the blasters/coaters. The bonnet CP has now got a slight bow in it Sad looks like I will have to try and remove said bow. 1999 Defender TD5 110
Regards
John M0VAZ
Post #868605 20th Nov 2020 3:44pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
No i wired it using the constant live from behind the drivers side speaker panel, took the wire over the back door and back down.
ive then got 2 ground wires for it, one is on the speaker panel directly behind it with a switch and the other goes to the dash with a switch so i can turn it on from the dash or the back of the car.
Fitting was a bit of a pain as my landy has always had a dent where the previous owner reversed into something and hit the reverse and no plate light. Part of the reason i bought this was to cover it up (good excuse). So i tried mounting it straight to the body but in was noticibly wonky pointing outwards so i took the old number plate light plinth and cut it diagonally into a little wedge about 2-7mm thick and then it was flat Bow down
It was quite useful having it off the body 5mm in the end as i could run the cable into the fatter part of the wedge and into the car which looks neater than having the cable showing
Post #868608 20th Nov 2020 4:03pm
bodstruck
Recovered my headlining
And bought a temp garage for the 110 to go in soni can paint it Smile
Post #868610 20th Nov 2020 4:05pm
That headlining is looking good, outstanding job! Thumbs Up
I need to do my Disco2 but I keep hesitating in case it turns out to be a disaster.
Post #868625 20th Nov 2020 5:05pm
bodstruck
I used 4 way stretch carpet from Ebay. 43 quid for a 5x2m roll and 5 cans of spray adhesive.
Quick YouTube review and then got stuck in. Very easy if a little messy with over spray from the glue.
https://www.ebay.co.uk/itm/320965717945
Post #868636 20th Nov 2020 5:39pm
However did we manage before YouTube? Very Happy
Post #868642 20th Nov 2020 6:04pm
Is that a random thought, or in response to something in particular?
Post #868668 20th Nov 2020 7:01pm
