Home > Puma (Tdci) > Steering Angle Sensor
tobyrm1
United Kingdom 2015 Defender 90 Puma 2.2 SW Santorini Black
Hi,
I’ve got a 2015 defender and it seems like the steering angle sensor is out of calibration when the steering is straight ahead I get a reading of 50 degrees and I think this is resulting in the feeling of slight traction control coming on when going over speed bumps.
I have a Hawkeye diagnostic that won’t calibrate the sensor back to 0 degrees. Can anybody tell me which of the diagnostic tools will recalibrate it or whether there is another way of doing it?
Thanks
Post #865122 2nd Nov 2020 10:30pm
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
Steering angle sensor, what is that?
Post #865605 5th Nov 2020 7:34pm
It's part of the dynamic stability control system fitted to the last year of production vehicles.
Sorry, can't help with the query. It may be worth asking the makers of the IID Tool as that's a very comprehensive diagnostic tool. Darren
Post #865630 5th Nov 2020 9:36pm
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Mine broke on my D3 many years ago and couldn’t drive as it kept putting the breaks on , had to reset it and glue it with apoxie glue , excuse my spelling Whistle , the IID tool can calibrate it I think .
Post #865640 5th Nov 2020 10:28pm
Martin
Site Admin
Yes IID has the routine
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #865679 6th Nov 2020 9:21am
jst
I have a dsc light that comes on the dash intermittently.
Fault codes show.ln below.
It comes on after steering input rather than abs or tc activation.
Would the osf wheel sensor cause dsc light or would that be more likely to trigger the abs/tc lights.
Vehicle
has recently had a new ignition barrel fitted.
Any advice? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1057721 18th Jan 2025 9:07am
andy63
I think the abs system is tied in with and reacts to input from the steering angle and yaw rate sensor..
All part of traction controll, dynamic stability controll
Post #1057726 18th Jan 2025 9:46am
Martin
Site Admin
Have you cleared the DTCs and see which come up when you get the lamp on?
Or have you done that and you get all of those?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1057727 18th Jan 2025 9:47am
jst
These were showing first off and cleared them.
Waiting to read again.
Does dsc element need calibration if it is at fault? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1057733 18th Jan 2025 11:55am
andy63
Dsc is just the term used to describe the interaction and responses of the abs, yaw rate and steering angle sensor.. it's not a specific unit or controller that can be calibrated as far as I know..
Post #1057739 18th Jan 2025 1:33pm
Ianh
When you had the ignition barrel changed did they remove the steering wheel ? I’m assuming they did.
If they did and inadvertently moved the steering angle sensor on the steering column then it will be out of calibration and need recalibrating with an appropriate tool such as the GAP IDTool. I’m pretty sure a Nanocom can’t do it.
Post #1057747 18th Jan 2025 3:04pm
jst
Cheers.
Error returned fault read again,
Cleared, steering angle sensor calibrated. Will see what it does next.
Yes I presume steering wheel removed when ignition changed. It's been driven for a week since that work was done.
It's a mate truck not mine. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1057769 18th Jan 2025 6:59pm
Oldowner
Nanocom can do it, I’ve used it a couple of times, it’s hidden away somewhere that I can’t remember off hand.
Post #1057800 19th Jan 2025 1:45am
Ianh
I read somewhere that the Nanocom can display the readings from the sensor. Therefore you can use those readings to manually set up the steering angle sensor correctly. However it’s not a dedicated recalibration process built into the tool and therefore more difficult and time consuming to utilise.
Post #1057832 19th Jan 2025 11:17am
jst
I have done it off an Auetl. Recalibration is an option and it also gives live data feedback on sensor, presumably the only way to use the latternis by rotating the sensor so it reads zero/mid value straight ahead? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1057843 19th Jan 2025 12:53pm
