Home > My Defender > An Anorak's Utility Station Wagon |
My work here is done Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
31st Aug 2020 8:29pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17526 |
Part numbers for the brackets are:
- LR068818 LH bracket - LR068822 RH bracket Google these part numbers and several suppliers will miraculously appear, also available via ebay sellers. See also https://www.defender2.net/forum/topic33029.html |
1st Sep 2020 9:57am |
I plugged the part numbers into eBay, which was the easiest purchasing route (notwithstanding that I've been sent the wrong one!). They cost around £30 each. I also bought new nuts, which are M16 x 1.5 nylocs. Darren
1st Sep 2020 10:11am |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 456 |
Many thanks both, I will get a set of those ordered, then work out what to do with them!
Cheers all as ever Also read the post as per the link, will this fix apply to my 90 as well as the 110? Cheers. |
1st Sep 2020 10:15am |
The original recall didn't include 90's but the brackets will fit just the same. Darren
1st Sep 2020 10:42am |
Cool thank you.
1st Sep 2020 10:48am |
Indeed, the original recall not include 90s but they still fail all the same. See https://www.defender2.net/forum/topic55655.html |
1st Sep 2020 11:11am |
Is there still an alignment issue whereby the original flanged nuts will not seat correctly?
1st Sep 2020 11:31am |
Almost certainly, yes. A standard nut just about fits into the recess in the bracket but I can't see how a flanged nut would. The clearance is such that I also couldn't get a socket on one of the nuts and had to use an open spanner. Darren
1st Sep 2020 12:04pm |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
Hmmm - I have just received my brackets today and the LR flanged nuts fit the recess. Maybe the design has changed slightly? Click image to enlarge Rgds. Chris |
2nd Sep 2020 12:53pm |
Hmm, ok. I think the problem may lie with the alignment of the two holes in the bracket with those on the axle. When I fitted mine, I put the first nut on without issue but with second, the bracket was positioned such that a socket wouldn't fit over the nut without fouling. I managed to get it to fit with a spanner but it wasn't quite central with the machined flat on the bracket, which leads me to believe that a flange nut wouldn't fit. It's basically a pretty tight tolerance. Darren
2nd Sep 2020 2:14pm |
I don't remember any issues with mine when I fitted them either. Maybe the issue is tightening either nut full before the other has seated? |
2nd Sep 2020 3:47pm |
I'll take another look when I get the replacement for the drivers side. Darren
2nd Sep 2020 9:03pm |
I have not had time to fit these today but I ran the vernier callipers over the components - there is a good 1 mm clearance on diameter between the O/D of the LR flange nut and the recess in the reinforcement piece. Rgds. Chris |
2nd Sep 2020 9:06pm |
