Home > My Defender > An Anorak's Utility Station Wagon |
Darren
26th Aug 2020 9:59pm |
For some time now, my Defender has been suffering from a strange intake-related noise, almost like that of a dump valve fitted to boy racer hot hatches, and occasional power delivery hiccups, which were explored in this thread a few weeks ago. I even took it to my local independent LR garage, who couldn't find anything wrong. Anyway, as a bit of a gamble I decided to replace the turbo actuator, which seemed to be a likely suspect for the problem and so far, so good!
The actuator is located on top of the turbo on the right hand side of the engine and is relatively easy to access. It's secured with three torx head countersunk bolts through the turbo casting and is connected to the acuating rod for the vanes with a small circlip. The latter has a slot in the end to make it easy to remove with a small flat bladed screwdriver. There is also a large multi-plug that needs to be disconnected by squeezing the tabs on each side. The old one removed showing the connector to the actuating rod: Click image to enlarge The new one prior to installation. The original is a Hella part whilst this is obviously a pattern part, purchased from eBay. The significant number when finding a replacement is the 'G-72' stamped on the side, which also exists on the Hella unit under the dirt: Click image to enlarge With the original unit removed I was able to check that the linkage was free and also add a bit of lubrication for good measure: Click image to enlarge And the new unit bolted into place: Click image to enlarge The whole job only took about half an hour to do and was quite easy. The results were immediately obvious with much smoother power delivery in first and second gear and no odd noises from the air intake. A definite result! Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 30th Aug 2020 9:12pm. Edited 1 time in total |
30th Aug 2020 12:48pm |
Ah, I've just put details in the dedicated thread linked above. The short answer is no, though. It runs smoothly (slightly noisy in one direction) and there's no obvious reason for it to stick. Time will tell, I guess. Darren
30th Aug 2020 4:15pm |
A week or so ago whilst looking in the engine bay for something completely unrelated, I noticed that the wiring to the MAF sensor was damaged:
Click image to enlarge Click image to enlarge I can only assume that this is vibration damage, as this plug is at the end of quite a long section of unsupported loom. Fortunately, help is at hand from the forum shop where it's possible to buy both new plugs and pre-wired plugs with a longish tail of cables. I opted for the latter, which turned up the next day: Click image to enlarge After removing the loom tape, opening up the split flexible conduit and carefully unwrapping more loom tape, I exposed the cables feeding this plug. With the new plug and loom section laid alongside, I cut each of the four cables in turn with each cut staggered by a couple of inches from the last. This was to to avoid a bulky section of cable that wouldn't fit back inside the conduit. I then trimmed the insulation from each cut end and spliced the together with solder sleeves: Click image to enlarge This is the first time that I've used the solder sleeves and they're quite neat, if a little fiddly. And it all back together again: Click image to enlarge It isn't shown in this picture but I also cable tied the conduit to the foam reinforcement of the pipe behind, just to give it a little bit more support. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
30th Aug 2020 9:08pm |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5859 |
Um, LRA, there’s a glaring reason. It was fitted into a Defender by JLR. All the reason a part needs to fail.... Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
31st Aug 2020 6:00am |
Heh, heh, I was hoping for something a bit more specific Darren
31st Aug 2020 7:00am |
Today's escapade involved fitting retaining brackets to the ends of the front axle, as discussed HERE amongst other threads. I shouldn't really need these brackets on my 13MY Defender as the issue they are designed to resolve only affects 11/12MY vehicles. However, there have been a few reported cases of axles failing outside of the specified VIN range and, for the cost involved, it's better to be safe than sorry.
I purchased the two brackets and new nuts a few months ago from two different places and they've been carefully wrapped up in a box since. The eagle eyed will spot the obvious issue that I didn't notice at the time of purchase: Click image to enlarge Yes, that's right - I have two LH brackets I didn't spot this until I'd already stripped down the right hand side, which involved a monumental struggle to remove the existing nuts, and there was a fair amount of cursing when I did Still, on the plus side, the mounting nuts have now been freed off and fitting the correct one when I sort it out will be easy. The brackets mount on the two bolts that secure the radius arms to the axle. The two on the drivers side in particular, put up quite a fight and I had to resort to a 3ft long tube over the ratchet handle to persuade them to let go! Click image to enlarge Click image to enlarge With the area cleaned up and a liberal dosing of Dinitrol on the mating surfaces, it was relatively simple to bolt the bracket into place (on the LH side): Click image to enlarge Click image to enlarge So there you go - a bolt on accessory that I hope I'll never need. Edit: I did eventually get the correct RH bracket and fit it some months later. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 6th Jun 2021 9:45am. Edited 1 time in total |
31st Aug 2020 3:41pm |
Whilst I had the front wheels off, I also took the opportunity to fit some galvanised brake disk shields:
Click image to enlarge These are Britpart items and whilst I generally have a healthy scepticism about their stuff, I figured how could they go wrong with something that has no moving parts? Easily, it turned out - the spot weld intended to secure the bracket that mounts to the lock stop bolt had failed on one of the shields, so I had to drill it out and rivet the parts together With that little drama taken care of, the actual fitting was quite straightforward. Each shield is secured with the aforementioned lockstop bolt and a small 6mm bolt through a 'T' shaped bracket that hangs from the bottom of each swivel housing. That bolt is odd as it has an 8mm head whilst the nut is 10mm. I did plan to replace those 'T' shaped brackets too, with some stainless replacements shown in the above picture. However, when I undid the first bolt into the bottom of the swivel housing the swivel grease started to drain out, which I wasn't prepared for! It turns out that there is a way to drain the later swivel housings after all. The brackets went back in their packet for the time being Anyway, apart from that moment of excitement, the shields fitted straight on: Click image to enlarge Click image to enlarge The old shields weren't bad but were beginning to show their age. Hopefully, these new ones will last much longer without too much attention. I also took the opportunity to adjust the lock stops to gain a little more steering lock whilst I had them apart, so that will be nice Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 5th Jan 2021 2:16pm. Edited 1 time in total |
31st Aug 2020 4:02pm |
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 |
Brilliant post: my 2.2 has from new suffered (albeit too strong a word) from the occasional power surge followed by a strange turbo noise for a few minutes, the problem has mystified LR warranty (well there's a surprise) & only does it occasionally, perhaps once a month. I've always suspected it was linked to the turbo & this post would appear to be related to my issue, so thanks for flagging this up. Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains |
31st Aug 2020 4:21pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17480 |
Take some comfort from the fact that every single failure of a front axle flange that I have seen or heard about so far has been on the NS end of the axle tube. I don't know why this should be.
It beats me that a firm can be so consistent with its production and supply of absolute junk with no quality control and - seemingly - thrive. It is truly awful that they peddle such crap and get away with it. |
31st Aug 2020 4:53pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3331 |
As long as people continue to buy it they have no reason to up the quality. WARNING.
This post may contain sarcasm. |
31st Aug 2020 5:04pm |
I think the original paperwork from JLR only mentioned issues with the LH side, but I guess even they couldn't be so tight as only address the one side.? |
31st Aug 2020 5:37pm |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
Thanks for this Darren - something else to go on the list that I didn't realise I needed to do! Rgds. Chris |
31st Aug 2020 7:55pm |
That's encouraging...I think
I think that part of the problem is that they're not consistent - not anymore. Some of the stuff they sell is pretty good, or are regular branded items, but it's often difficult to know what you'll get until something actually turns up. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
31st Aug 2020 8:27pm |
