![]() | Home > Expedition & Overland > Henri the 110 goes pop top! |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 566 ![]() ![]() ![]() |
Looks great inside. Well thought out.
Having just ordered an Alu-Cab roof I need to sort out the inside design amongst everything else! May I ask how you are heating the water (if indeed you are) really struggling to decide which is the best way to go. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper Last edited by db950 on 27th Jul 2020 8:11pm. Edited 1 time in total |
Very helpful thank you.
I’m also considering just a canister system for storage but worried about the amount of internal space they will take up. I guess it would be a good starter system that could be upgraded as time and money allow. I’ve been looking at gas powered and electric powered water heaters, haven’t ventured into heat exchangers and such yet! Thanks for the Bullfinch idea, looks like a neat shower solution. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10894 ![]() ![]() |
Nice to see the fabrication in the metal, looking good so far
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8175 ![]() ![]() ![]() |
Thats great, thank you. Is it one way do you know? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025 ![]() ![]() ![]() |
Badger110 has a good thread going regarding heat exchangers.. |
Just had a quick read, used for filling an internal tank via a tap or pumped from a container into an internal tank. Just use a shower outlet point if you want it the other way around. |
One side finished just checking doors & fittings before it goes back to be touched up & powder coated.
looking good and functional. is it heavy? Cheers
Hi James, not as heavy as you’d think. Going to weigh both sides just out of interest. Guess 35kg....
Looks great
![]() How are the doors going to be held in place? 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
Bit of a late reply! Basic push button catches which are both simple & look good.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge The MDF is only ten plating for the caramel bamboo.. |
Ah yes, will probably use the same catches, like you say they look neat.
Looking good in there, are you fitting a sink/hob in the worktop? 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
No hob but a small polished stainless sink with filtered water.
Been looking at the hinges for a while, totally shot so Optimill all round.
![]() Click image to enlarge ![]() Click image to enlarge |
