Home > Expedition & Overland > Henri the 110 goes pop top! |
Steve_overland Member Since: 14 Oct 2018 Location: Gaydon Posts: 290 |
Thant’s a cool idea and super simple ... @steve_overland on Insta. 110 expedition vehicle with pop roof |
21st Jun 2020 8:34am |
Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025 |
Thanks Steve, just wanted something tough & cheaper than a steel one. Would have had one of Errol’s but logistically it just didn’t work. All in with a brand new case it cost £225.00 including back plate & ss fixings. If a good second hand one would have come up it would be £90.00 cheaper.
21st Jun 2020 9:03am |
I have fitted rails on the driver side of ours now so would consider his option going forwards....
Click image to enlarge But have now fitted out the kitchen on the passenger side of ours Click image to enlarge Click image to enlarge @steve_overland on Insta. 110 expedition vehicle with pop roof |
21st Jun 2020 10:00am |
Very nice, dead easy to access..
21st Jun 2020 10:19am |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 560 |
Thank you. Also, where on earth did you find that Peli Case so cheap? 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
22nd Jun 2020 8:31am |
Ha, it was £180.00 new with foam delivered! Place on line Jigsaw 24.
24th Jun 2020 10:09pm |
So, still waiting for the fabricators on the kitchen so little jobs
Move the towing electric’s into the x member Gwyn Lewis mud shield Pull the services ( water & power through the chassis) Old Man Emu steering damper. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
28th Jun 2020 10:11am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8139 |
those gwyn lewis guards are one of the first mods i do to mine after a steam clean and chassis protection. i also cable tie the bottom of the rear like you have done! Cheers
28th Jun 2020 10:48am |
They’re good aren’t they James, the locker is the other side so Gwyn kindly sold me a single ( great bloke) as for the cable tie it just stops it flapping at the bottom about the only thing that you can do.
28th Jun 2020 12:19pm |
So, trip down to the fabricators. 1st fitting of the main unit & apart for a corner to be cut ( to give a panel some more tolerance) it’s looking good.
27th Jul 2020 9:26am |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
I do rather like the water connector for the back window blank ... and its one of the many ‘I’d like to do that’ jobs !!
Thinking of having some gas and water connectors at that point for the outside use ... The list grows longer every day! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
27th Jul 2020 9:41am |
Ha....like triggers broom Gary! You probably know this, panels from Kevin at Mud & connectors from Bullfinch. Work very well & dead easy to do.
27th Jul 2020 12:35pm |
is the water connector from Bullfinch - i looked but they only seem to do gas Cheers
27th Jul 2020 2:08pm |
https://bullfinch-gas.co.uk/outdoor-utilit...ter-detail
Is this what you were looking for ? |
27th Jul 2020 2:44pm |
