Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 75 of 81 <123 ... 747576 ... 798081>
Grenadier
mk1collector wrote:
Rear axle oil seal decided to give up this week so it’s going in for both sides replacing on Friday And new pads as they were drenched Big Cry so I cheered myself up by giving it the first wash it’s had in a few months Whistle
Ray, looking good.
On the seals, I just put on some HD flanges and have noticed some oil around the hub and splashed on the wheel. Just one side, all clearly coming from the area of the flange cap, but do you think this is what it could be? Is it a DIY job? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #843824 15th Jul 2020 7:33am
mk1collector
Hi, I’d check if there’s just oil on the flange side, I have hd flanges on already and was hoping that was the problem. Unfortunately I took the wheel off and it’s coming out at the axel end, with lots of oil on the back of the disc working it’s way to the front via the calliper Big Cry I’ve cleaned it all off with brake cleaner and parked it up till it goes in on Friday for both sides Axle seals doing just in case. Thumbs Up If yours is just on the flange side then you might not have tightened the nut on the new flange up enough (when I first got mine on I didn’t tighten one of mine enough and the nut escaped through the centre cap at some unknown time while driving Big Cry and it took a while to find a replacement) your best getting it checked sooner than later as oil on the brakes is not good especially in the hills you live in. If oil is just around the flange you could fit a new gasket as well just to be safe which IMO is a diy job, just a few bolts. Ray
My build thread
Post #843849 15th Jul 2020 10:19am
mk1collector
As I haven’t been driving her this week waiting to go into the garage I thought I’d tidy a few things up I’d been meaning to do. I gave It a wash, put the trim back in from fitting the new scenelight, cleaned up the oil from the leaking axle and striped some old wires out that I’d run to the back.......... all was going well I thought until I had to drop the kids off at school today before dropping the car off at the garage for the work doing. That feels odd I thought as the brake pedal went to the floor Shocked unfortunately I was half way around the trip when this happened so no leaving it at home to sort later. My first thought was that the fluid at the back must be brake fluid from a split pipe and not the axle seal I thought it was, so pull over and get one of the kids to pump the pedal, nothing squirting out at the axle end Question then I noticed dripping from underneath the drivers door area!!! I’d only gohe and cut through my own brake line while cutting the cable ties for the wires I’d stripped out Embarassed it was a very slow drive to the garage and a lot of blushing as I explained. Ray
My build thread
Post #844074 16th Jul 2020 1:04pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Spotted down at Parkside today Thumbs Up
Post #844159 16th Jul 2020 10:16pm
mk1collector
I don’t think Mick was happy with my embarrassing blunder as he was busy and had squeezed me in for the axle seals doing Rolling with laughter Ray
My build thread
Post #844171 16th Jul 2020 11:58pm
mk1collector
I wired up my aftermarket heated seat loom to the genuine switches in the dash today. I kept switching the aftermarket switches on and not noticing till I was getting very hot in the nice weather we had a few weeks back, so now I switch them on with the genuine dash switches (which will be much harder to knock accidentally) and the aftermarket switches are used to switch between the heat settings. No more hot seat for me unless it’s cold outside Mr. Green This week I’ve been continuing the prep and painting of the chassis too when it hasn’t been raining, but that may have to be put on hold for a while as the forecast doesn’t look good Big Cry
Edit: I also got it back from the garage with working brakes Embarassed and no more leaks from the rear axle! That was an expensive mistake!! Ray
My build thread
Post #845376 22nd Jul 2020 10:29pm
L110CDL
Good that your not getting hot under the collar anymore Ray Wink
These sort of easy mistakes keeps you on toes and hopefully think twice in the future Very Happy Clayton.
Keeper.
Post #845787 24th Jul 2020 9:16pm
mk1collector
Thumbs Up Hopefully any more mistakes won’t be as expensive Big Cry I’ll be glad when all the chassis cleaning, painting and waxing is done too as I’m getting bored of being filthy and gritty every day Rolling with laughter doing the rear axle today. Ray
My build thread
Post #845949 25th Jul 2020 4:52pm
L110CDL
You must be near the end now of getting dirty Ray Laughing Thumbs Up Clayton.
Keeper.
Post #846499 27th Jul 2020 8:31pm
mk1collector
I’m doing it all in sections and doing the wife’s dc too so I’ve got at least another week in total but trying to fit in around weather and kids and when the wife isn’t at work to do hers is dragging everything out quite a bit Big Cry Ray
My build thread
Post #846552 27th Jul 2020 10:53pm
L110CDL
Didn't realise you was doing the DC as well, no wonder your getting bored of doing it, i wish you all the best on getting it done sooner rather than later Thumbs Up Clayton.
Keeper.
Post #846560 27th Jul 2020 11:17pm
mk1collector
A few more bits arrived today for the ongoing chassis clean up.
 Ray
My build thread
Post #848012 4th Aug 2020 2:40pm
mk1collector
A bit more turned up. New metal a bar top mounts (instead of the rubbish plastic Landrover ones) just in case I decide to fit the a bar. Service items as it’s getting to that time of year again and bulkhead hinge bracket gaskets and fitting kit for when the windscreen surround gets painted.
Also new screen to go in when the paint is done because I can still see the repaired stone chip and it annoys me Whistle
 Ray
My build thread
Post #848191 5th Aug 2020 12:54pm
mk1collector
Well those bits look a little worse for wear! Shocked
Lots of sanding cleaning prepping and painting later and we have this.
New ones of these
And a rubbish pic as I didn’t finish putting it back together till just after midnight Big Cry so I wasn’t taking the wheel back off for a picture today Rolling with laughter
It took ages to do with all the fiddly nooks and crannies to sand and clean and I still have the other side to do Big Cry but I’m getting close to the finish now. Ray
My build thread
Post #848838 9th Aug 2020 2:21pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Looks mint. I want to give mine this sort of treatment.
Was it dinitrolled before?
Post #849030 10th Aug 2020 1:36pm
