Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 76 of 81 <123 ... 757677 ... 798081>
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Looking really good there Ray. Top job Thumbs Up 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #849041 10th Aug 2020 2:20pm
mk1collector
@ Landymanstefan, Not really, it had had bits sprayed over here and there but not a proper job at all. As seems to be the case the front end of the chassis was better than the rear but it’s coming up good Thumbs Up once it’s all painted it’ll be getting built hamber Clear wax all over it So it’s easier to spot if any corrosion starts again. Ray
My build thread
Post #849043 10th Aug 2020 2:24pm
mk1collector
Thanks rosco Thumbs Up Ray
My build thread
Post #849044 10th Aug 2020 2:25pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Well the results look great!
I have a fairly transparent wax on my chassis and I’m just starting to see bits of corrosion poking through. I want to paint with some heavy duty paint for a more permanent solution but getting the old wax off is a nightmare.
Any tips?
Post #849107 10th Aug 2020 5:15pm
mk1collector
I’ve been using a mixture of Nylon strip discs on an angle grinder and various wire wheels on a drill to get the main wax and muck off, then using the full por15 system, first you use their (quite strong) degreaser then wash the area off and dry (repeat as necessary) then the por15 metal prep (which I think converts rust and etches the metal) then wash and dry before painting so all the metal gets thoroughly cleaned and the paint sticks well. Ray
My build thread
Post #849121 10th Aug 2020 5:50pm
LandymanStefan
Awesome thanks i’ll look into it. I did a small area of my chassis with a scraper and a flap wheel in a drill but it kept getting so clogged it was a nightmare.
Post #849180 10th Aug 2020 8:53pm
mk1collector
I found the same with sandpaper type discs, the nylon strip and clean discs don’t clog anywhere near as bad and the wire wheels can be wire brushed out if they clog at all. It is a horrible dirty job though, with dirt and rust flung at your face for hours Big Cry and make sure you have a good supply of disposable gloves and cheap brushes if you use the por15. I ran out of gloves over one weekend and managed to burn my hand with using the degreaser because I stupidly was determined to keep going Rolling Eyes Ray
My build thread
Post #849206 10th Aug 2020 10:39pm
L110CDL
Finally had 5 minutes on the way to work this morning to get these pic's for you Ray, i have seen this one a lot and lives where i took the pic
Thumbs Up Clayton.
Keeper.
Post #849852 13th Aug 2020 9:20pm
mk1collector
Thumbs Up Liking that. The banded steels look great! Ray
My build thread
Post #849889 13th Aug 2020 11:42pm
L110CDL
Thumbs Up Clayton.
Keeper.
Post #850794 18th Aug 2020 9:24pm
L110CDL
Well Ray, i have been passing this one for a few weeks now and it had a cover on until we had the strong winds and the cover came off, so i took a quick pic this morning for you as i think it needs your magic touch . . . . .
Whistle Clayton.
Keeper.
Post #852737 28th Aug 2020 8:37pm
mk1collector
Looks like it fully stripped out that one. The tailgate will go missing if anyone sees it because they’re worth a bit and easy to take off (just like a defender bonnet really) tow it up to mine for me and I’ll get on with it Thumbs Up Rolling with laughter Ray
My build thread
Post #852911 29th Aug 2020 2:14pm
L110CDL
I will see how long it takes before the cover goes back on and i didn't think that you had the room for another project Ray Wink Clayton.
Keeper.
Post #853432 31st Aug 2020 9:00pm
Grenadier
Whistle
What’s with the house name? Worse than ‘Dunromin’ Rolling Eyes Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #853498 1st Sep 2020 7:01am
mk1collector
Always room for more....... much to my wife’s annoyance Rolling with laughter Ray
My build thread
Post #853552 1st Sep 2020 11:05am
