Home > My Defender > An Anorak's Utility Station Wagon
Page 36 of 57 <123 ... 353637 ... 555657>
Yeah, not so keen on that, to be honest. I want to be able to push it in from one end without having to think about whether the pointy end has found its' mark. If it becomes a big issue then I may revisit the tube but I'm not too concerned. Darren
Post #841602 3rd Jul 2020 6:54pm
I was out and about yesterday and managed to snap this view that I think looks pretty cool. Roof bars back on, as I'm transporting my Ozpod for the last time tomorrow.
 Darren
Post #841605 3rd Jul 2020 7:03pm
L110CDL
Loving that pic Darren Thumbs Up
You have been busy with the mods/upgrades to the 110, all great and with great execution Bow down 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #841617 3rd Jul 2020 7:47pm
Heh, heh, thanks. It keeps me off the streets Laughing Darren
Post #841662 3rd Jul 2020 9:10pm
L110CDL
Laughing 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #841669 3rd Jul 2020 9:32pm
HardCharger
Re: Umbrella Holder
Supacat wrote:
LandRoverAnorak wrote:
Next up was another small step towards my perfect stowage solution, an umbrella holder! This has to be one of the most simple modifications on the planet, merely consisting of a 750mm length of 2 inch plastic pipe (I know I'm mixing my units Laughing ) cable tied to the rear of the front legs of the '60' part of the second row seats:
This places my umbrella immediately to hand when the door is opened:
An embellishment of the idea could be to drill a series of holes in the side of the pipe to allow a wet umbrella to dry out but I only thought of that after I'd fitted it, so it'll do for now.
If you left it open in the middle, it would air dry, and a lower mounting would allow it to drip onto the rubber mat rather than uncovered metal:
I like this set up! How will they be if the seats are folded forward? What size are the pipes and how are they secured? Difficult to re-holster?
I have a bunch of large umbrellas under the second row and they would thud around during sharp turns. This set up makes things look more "official" plus 2 large umbrellas should be good enough for about 5 people anyways, right? Is there a way to install a 3rd umbrella? I'm realizing that I use one of the large umbrellas just for myself. I guess I can do another holster set up where LRA put his kit Thumbs Up
Post #842003 6th Jul 2020 2:04am
Post #842022 6th Jul 2020 7:58am
Soundproofing Part 3 - Drivers Door
I've had a few niggling issues with the drivers door and yesterday was the day to sort them out.
Firstly was an alignment issue. I'd noticed that when driving over particularly rough roads or speed bumps, there was a thumping noise from somewhere near the top of the A pillar. After a bit of trial and error, I discovered that the top edge of door was hitting the underside of the roof gutter as it flexed, as the gap was very small. I loosened off the hinge bolts into the bulkhead and with a bit of pulling and percussive persuasion, moved it down and back slightly, which seems to have cured the problem.
The second job was an annoying rattle inside the door. I whipped off the door card (no clips broken - yay) and peeled back the water shedder to reveal the innards. This was done by carefully slicing the mastic with a sharp knife whilst pulling the shedder away from the frame and means that it goes back on very easily.
The problem was immediately obvious:
The white plastic clip highlighted above had come unstuck and the rod that it's supposed to guide was rattling against the inside face of the window regulator panel that it runs along. I cleaned up the clip and applied new double-sided foam tape and it was good as new. A nice, easy fix Smile
Whilst I had the door apart, it made sense to install some sound proofing. After a bit of a clean up and degrease, I first added a layer of Silentcoat to the lower half of the door. Without a lot more dismantling, it's quite difficult to gain access to the top half but I used the same approach on new doors for my old 90 and it worked well:
I also applied some smaller offcuts to parts of the regulator panel for good measure.
Next, a layer of self-adhesive foam was added. It looks a bit scrappy as I didn't have much left in stock and had to cut and shut some smaller pieces but the good thing about this sort of stuff is that it doesn't have to look pretty to work:
With the door card back in place, the door now closes with a satisfying thunk instead of the tinny rattle that I've put up with for two years, which is nice Very Happy
As a series of tasks, they all went surprisingly well, with one small exception. Whilst installing the Silentcoat with a seam roller, I caught my thumb on the window regulator gear wheel and ended up dripping a fair amount of blood all over the place:
'Fiddlesticks' I said Rolling Eyes Darren
Post #851539 23rd Aug 2020 8:13am
L110CDL
Nice couple of " easy fixes " there Darren, makes a change when it goes all to plan, but not blood everywhere though Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #851998 25th Aug 2020 7:39pm
It's ok - it's settled down to a dull throb now Laughing Darren
Post #852015 25th Aug 2020 8:41pm
90 Dreamer
"'Tis but a flesh wound".......... Mr. Green
Post #852017 25th Aug 2020 8:53pm
Rolling with laughter Darren
Post #852018 25th Aug 2020 8:55pm
L110CDL
Sudocrem or germolene ( not sure if either are spelt right Rolling Eyes ) always help the throb to go away Wink 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #852019 25th Aug 2020 9:12pm
Or Baileys... Laughing Darren
Post #852027 25th Aug 2020 9:35pm
L110CDL
Agree with you there Darren Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #852245 26th Aug 2020 8:30pm
