Home > My Defender > Grafty's Td5 90 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4792 |
They feel good at slow speed, haven't been out on the road yet as it's SORNed at the moment. Will report back when it's taxed
I use acid free wheel cleaner at the moment as its fast and easy. Have recently been thinking about switching to fallout remover such as Merlin Blood anyway as it supposedly safe for all finishes 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
19th May 2020 6:35pm |
Looking forward to see how they go, once bed in
19th May 2020 7:05pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10844 |
Nice upgrade there George Clayton.
19th May 2020 8:43pm |
Thanks chaps
Having eyeballed the rear brakes. I think the original fronts may fit in the rear (so 4 pot vented) obviously this may cause too much fluid movement and therefore too much pedal travel. Will run it as is for a while though 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
19th May 2020 8:56pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5216 |
really do fill the wheel out those discs do! you could have fitted HD drive flanges
As for rear brakes i would just give them a disk and pad upgrade, Might be a little bit over kill if you have beefed up fronts. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
19th May 2020 9:52pm |
Do you tax your motors every 6 months are yearly? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
19th May 2020 9:55pm |
LOF do a 4 pot rear conversion that matches the front. Might end up with those yet
I tax all of my vehicles yearly - however as I haven't been going anywhere I SORNed everything at the end of March as it seemed a waste to have them sat taxed and not going anywhere 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
20th May 2020 6:33am |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2916 |
you need to get cold bite pads, what made you choose these over the AP kit from Ian? Looks to the same kit that Luke has just branded? Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
20th May 2020 6:38am |
I did choose cold bite pads, no sense in having big brakes if the first few applications are worse than standard
I chose these over AP, works or bowler etc purely on cost. I can't see why they won't deliver similar performance for £3000 less than works brakes and £2000 less than the bowler setup. Time will tell I'm sure, but I'm happy for now 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
20th May 2020 6:54am |
you are dead right, when I am at that stage I will need to look at them and get some feedback from you Andy
20th May 2020 7:02am |
For sure! I'll post an update when they're fully bedded in
When I was talking to Luke he said for a 90 just fronts should be sufficient but a 110 really benefits from their rear setup as well. That probably won't stop me getting the rears eventually though Another advantage to the LOF ones is that they have a wide variety of colours available 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
20th May 2020 7:20am |
Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313 |
Sure you won’t be disappointed Grafty!!
Looks like Luke‘s supplier is PBbrakes. I have been running a set of their 8 pot brakes for around 3 years now with no complaints. A whole lot better than standard, with great cold bite. Not saying they're on AP or Alcon's performance level but at less than half the price for 80% of the performance - ill take that! Dan is great at PB and has connections with drifting and time attack teams worldwide. 1989 90 4.3 V8 2012 L405 OF 2014 D4 HSE Lux (SOLD) 2015 90 HT (SOLD) @d9o.mf |
20th May 2020 7:56am |
are you going to do the diffs too at some point? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
26th May 2020 8:39pm |
Thats good new Matt, I'll update with my honest opinion when they're fully bedded in
Centre diff is already in a fully uprated transfer box (Ashcroft ATB) Front and rear diffs will be uprated at some point, slightly lower on the priority list as they'll be an upgrade on failure item 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
26th May 2020 9:09pm |
