Home > My Defender > Grafty's Td5 90
Page 110 of 124 <123 ... 109110111 ... 122123124>
Procta
grafty what did you do and use to stop water coming in your defender? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #836907 13th Jun 2020 12:56am
grafty99
When I rebuilt it, I used all new genuine seals. So that's door, roof to side panels,side panels to tub, roof to windscreen frame and windscreen frame to bulkhead. (tub to seatbox too, now I think about it).
Then using dumdum and cloth tape make sure all of the gaps in the door seal lips are filled.
As I fitted new doors they had the later lower seals - which are a big improvement over the early type.
After all that it's just a case of chasing any remaining leaks. I was lucky in the fact that I didn't have any after the rebuild Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #836946 13th Jun 2020 8:21am
Procta
spot on pal, looks like i will have to do some seal replacing on this and Dum dum. did you fit Cruse control to yours? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #837435 16th Jun 2020 1:35am
grafty99
Thumbs Up
Cruise control is a must! It's dead easy to fit and works immediately if you're on standard gearing. I use it all the time Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #837607 16th Jun 2020 6:41pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
I’ve looked at fitting cruise to mine, it does seem fairly simple although I’ve not got standard gearing... I’ve got a disco ratio in my t box.
How does this change things?
Post #837661 16th Jun 2020 9:08pm
grafty99
Fitting is the same, the only difference is you'll need to fit a speedo healer between the speedo and ECU so that the ECU thinks you're travelling slower than you are.
Speedo transducer
V
Speedo
V
*speedo healer*
V
ECU
I think there is a post somewhere on this very topic. I've been running taller gearing and a speedo healer for about 6 years, faultlessly Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #837672 16th Jun 2020 9:38pm
grafty99
It's been a while since an update, nothing much has been happening as we're extremely busy on site.
Good news though. I've just acquired a new tool for the 90 - an original nanocom. Can't wait to start fiddling Rolling with laughter
1990 Vogue SE
Post #851316 21st Aug 2020 5:44pm
^^^^ Same one as mine.... great little bit of kit.
Post #851322 21st Aug 2020 6:15pm
grafty99
Ahhh nice! I wonder how many people still use them? Probably not as user friendly as the new ones but I'm sure it'll do all I need Very Happy 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #851341 21st Aug 2020 8:30pm
bankz5152
Speedo transducer
V
Speedo
V
*speedo healer*
V
ECU
I've got mine ready to go as well! Im hoping that because my speedo reads bang on I won't need the healer. Also apparently you can tweak the ECU to suit any gearing/tyre size which would be ideal!
After driving a D2 for the past month with CC I MISS IT SO MUCH Laughing Instagram @defender_ventures
Empire Tuning - Agent
Post #851495 22nd Aug 2020 9:01pm
grafty99
My speedo is bang on, still need the healer though Rolling Eyes
I'm going to have a mess around with TunerPro now I have a nanocom and that's one of the first parameters I'm changing Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #851509 22nd Aug 2020 10:25pm
grafty99
First day off in a while today - got the genuine AC kit fitted to my 90 thanks to Steve_overland for delivering Thumbs Up
All plumbed in and fitted. I just need to work out the relays for the ECU to control the compressor clutch and condenser fan. If someone could tell me if the ECU pulls the relays to ground (I suspect it does) that would be excellent Thumbs Up
Anyway, here it is in the dash
1990 Vogue SE
Post #852190 26th Aug 2020 6:20pm
Martin
Site Admin
Yes it pulls them to ground Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #852196 26th Aug 2020 6:39pm
grafty99
Excellent, thanks Martin Thumbs Up
Black connector - pin 29 for compressor clutch and pin 4 for condenser fan if I'm reading the diagram correctly? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #852205 26th Aug 2020 6:56pm
LandymanStefan
Very jealous Thumbs Up
Where did you source the kit from?
Post #852230 26th Aug 2020 8:03pm
