Home > Puma (Tdci) > MY2011/2012 Recall Action P047/048 Front Axle Case |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17353 |
Yes, see earlier post in this thread.
6th Dec 2019 6:33pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1858 |
Ok, so finally got around to fitting them and they don't
The nuts have a built in washer/flange (sorry don't know their correct name) and these don't clear the new brackets, plus the brackets have a recess that looks like the nut should sit inside, which they won't. So, I am guessing the nuts need to be changed for the old type like on my tdi's which are just 'normal' nuts. Is that correct? If so, what size/spec are the nuts please so I can order some, as the shop at my local indi appears not to be open at the moment. 24mm socket size. Many thanks Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
25th Apr 2020 7:55am |
Can you post some photos to illustrate the issue?
25th Apr 2020 9:15am |
Good idea.
You can just see hopefully where the flange fouls the bracket Click image to enlarge Think I will just replace these type of nuts with these Sound like a plan |
25th Apr 2020 9:36am |
The nuts in your top photo are "flange nuts", a style which is extensively used on the Defender. Those in your second photo are nylon insert stiff nuts, commonly known as nylocs.
The radius arm bolts on the Defender are M16 but I think are 1.5mm pitch fine thread (not the standard 2.0mm pitch coarse thread). The correct nut for the application is ANR3140, which is a nylon insert nut with a small flange, which will (or at least should) fit the counterbore in the bracket and which look like this:- If you want to check the thread (I visually checked and it looks to me like 1.5mm pitch) try threading a Defender wheel nut on the exposed end of the bolt, since Defender wheel nuts are definitely M16 x 1.5mm. There is probably no reason why you should not use an M16 x 1.5mm standard (flangeless) nyloc, but you may find that it is just as easy, possibly easier, to obtain ANR3140. The corresponding flange bolt, M16 x 1.5mm pitch x 100mm, is RYG501550 should you need it (given that you appear to have non-standard nuts I suppose it is possible that you also have non-standard bolts). As 2016 was right at the end of production, it is possible that substitute parts were used, but the part numbers above are those listed for TD5 and TDCi vehicles. Incidentally they are also used on the P38 and probably many other Landrover products. Hope this helps. |
25th Apr 2020 1:18pm |
Awesome answer, thanks a lot.
Here is a pic of the existing nut in situ and yes a wheel nut threads on nicely, even if it appears a bit loose on the threads. Click image to enlarge In my haste to progress I ordered these earlier, which though a different part number will hopefully be ok MOD NOS apparently. Click image to enlarge |
25th Apr 2020 1:53pm |
Did those flanged nuts come with the brackets in a kit?
25th Apr 2020 2:30pm |
No the kit does not include nuts, just the bracket (the left and right brackets are sole separately for some reason, as if you'd only fit one!)
Carman, assuming that they are the right thread (again try one on the exposed thread before dismantling) they will be absolutely fine, there is no engineering requirement for a flange nut in that application. |
25th Apr 2020 2:40pm |
Perfect
25th Apr 2020 3:13pm |
Great tip Blackwolf and of course, they don't fit, as they appear to be the correct size, but wrong thread
Click image to enlarge Now to find ANR3140 x4 |
8th May 2020 12:35pm |
They are almost certainly a "standard" M16, which will be a coarse thread with 2.0mm pitch. You need a fine thread nut, with 1.5mm pitch. Perhaps inevitably these are harder to find.
M16 x 2.0 fittings are commonly used on towbars, any 2-bolt towball is likely to be secured with them. |
8th May 2020 12:57pm |
From a safety perspective a nyloc is a nyloc right, so as long as it is correct pitch I am assuming it will be safe
I'll get this job done eventually |
8th May 2020 1:01pm |
Yes, effectively all nylon insert stiff nuts ("nylocs") are equal.
8th May 2020 1:06pm |
M16 x 1.5 nylocs can be found quite easily. This was the first of many following a search on eBay:
https://www.ebay.co.uk/itm/Metric-Fine-Ext...f1tQ8gdaVw Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
8th May 2020 2:50pm |
