Home > Puma (Tdci) > MY2011/2012 Recall Action P047/048 Front Axle Case
Page 2 of 39 <123 ... 373839>
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Land Rover tdci Letter
Hi
Had this sent to work today, as we have some in the fleet.
Just thought it may be of interest to those of you who own one of that age!
I have seen it talked about, but just interesting to see what LR say about the issue.
Had to duplicate them on the post as i was not to sure if some could be read or not, (phone photo!)
 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #375872 2nd Dec 2014 7:55pm
Of course, if you were to steam clean the casing prior to going into your dealership, and some EP90 accidentally got smeared around the weld and looked like it was leaking...... Whistle Whistle
Post #375879 2nd Dec 2014 8:16pm
Caterham
Letter landed today.
Sounds like a right bodge rather than fix the problem its just a case of minimising the adverse effects......
And something of an understatement suggesting you might loose stability..... Shocked
Post #375894 2nd Dec 2014 8:44pm
jst
letter here today too.
like blackwolf i grinned at the lack of stability comments.
will check mine over and see what it looks like!
bracket option is i guess a low cost reassurance option as they dont feel it likely to happen....? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #375923 2nd Dec 2014 10:07pm
TJ101
Covered here http://www.defender2.net/forum/topic33029....ddc2009833
Very Happy
and yes,, got one for my 11 plate 110 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #375926 2nd Dec 2014 10:08pm
Fifth Horseman
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Regards the comments about stability in the event of the weld fracturing, I wonder if the bracket also surrounds the flange bolt heads. If it does not then god knows what will happen when the brakes are used as there would be nothing to stop the now free end of the axle from rotating with obvious effects on the steering and brake hoses.
Another question which is not answered by the Q&A is what is JLR's liability in the event of weld failure subsequent to the fitting of the bracket? I would hope that in this case they would pick up the cost of any damage.
Also, got my letter today.
Post #375939 2nd Dec 2014 10:25pm
Martin
Site Admin
Seems that vehicles with HD suspension get a new axle case, those with standard suspension get the brackets.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #375953 2nd Dec 2014 10:44pm
dgardel
Italy
The bracket.......
horrifying solution..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #375965 2nd Dec 2014 11:13pm
dgardel
Italy
If the owners of PUMA crying, the TD5 ones not laugh
The breaking point is different (is the bowl)
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #375969 2nd Dec 2014 11:18pm
Yes, it definitely looks to me as though vehicle stability has been compromised and there has been a reduction in directional control.
Alternatively as a normal person might observe, it looks rather as though the b****** wheel's come off!
Post #375986 2nd Dec 2014 11:45pm
Dean Watson
United Kingdom 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Mines now booked in for the 22nd has anyone had the bodge, sorry repair fitted, I phone both the dealer and landrover customer assistance to ask what would happened if the weld still broke , because although the wheel would still be attached by the marvel of retro engineering(bracket) I would still have a broken axle, the silence was deafening and I was told
"its been approved as an engineering solution"!
Anyone else a bit nervous of this bodge, sorry engineering solution? Whistle
Deano
Post #376050 3rd Dec 2014 1:17pm
dgardel
Italy
Dean Watson wrote:
I was told "its been approved as an engineering solution"!
Deano
www.youtube.com/embed/rp8hvyjZWHs
IID Pro MV License
Post #376063 3rd Dec 2014 1:56pm
dgardel
Italy
p.s.
I'm an engineer, mechanical engineer .....
....trust me Rolling with laughter Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #376064 3rd Dec 2014 1:58pm
It is an interesting situation (and I am sorry for those whose vehicles are in the affected range).
The reinforcing bracket is clearly intended (from the documentation) simply to retain the hub assembly in the event that the axle breaks rather than to prevent the axle breaking, since the paperwork states that with thebracket fitted a crack will be evidenced by oil leakage and abnormal steering behaviour, which, especially the latter, doesn't really seem satisfactory.
it is also not clear what happens if you have a bracket fitted and then the axle breaks anyway - will LR then replace the axle casing FOC for you, or will it consider that its responsibilities were discharged with the fitment of the bracket.
Has anyone actually seen one of the brackets yet? I would be interested to see a photo of the bracket prior to fitting to see how it actually retains the broken flange and hold the axle together.
It also looks to me as though fitting the reinforcement bracket may affect the turning circle since it possibly interferes with the lock-stops.
To keep it in perspective it is clearly quite a rare failure and the chances of it happening are small. The consequences however could be severe, hence no doubt the reason for it being treated as a recall. I wonder how many have ffailed in this way but not been reported to LR.
Post #376067 3rd Dec 2014 2:02pm
keith
Called my dealer today and emailed the letters and link to this site as I have this model car . I'm told that their extensive searches , questions to LR and computer searching has shown NO PROBLEMS ON THIS ISSUE and no recalls . The only highlighted area is for Left hand drive European vehicles . Even after they shown your arrived today from LR letters .
Is there any more info please on this recall ?
Keith
Post #376181 3rd Dec 2014 9:28pm
