Home > Puma (Tdci) > MY2011/2012 Recall Action P047/048 Front Axle Case
Page 11 of 39 <123 ... 101112 ... 373839>
CarMan
Noted, thanks. Are they a relatively easy DIY job to fit Question Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #804941 6th Dec 2019 8:57am
Yes, see earlier post in this thread.
Post #805034 6th Dec 2019 6:33pm
CarMan
Ok, so finally got around to fitting them and they don't Rolling Eyes
The nuts have a built in washer/flange (sorry don't know their correct name) and these don't clear the new brackets, plus the brackets have a recess that looks like the nut should sit inside, which they won't.
So, I am guessing the nuts need to be changed for the old type like on my tdi's which are just 'normal' nuts.
Is that correct?
If so, what size/spec are the nuts please so I can order some, as the shop at my local indi appears not to be open at the moment. 24mm socket size.
Many thanks Thumbs Up Rob
Post #827525 25th Apr 2020 7:55am
Can you post some photos to illustrate the issue?
Post #827548 25th Apr 2020 9:15am
CarMan
Good idea.
You can just see hopefully where the flange fouls the bracket
Think I will just replace these type of nuts
with these
Sound like a plan Question
Post #827553 25th Apr 2020 9:36am
The nuts in your top photo are "flange nuts", a style which is extensively used on the Defender. Those in your second photo are nylon insert stiff nuts, commonly known as nylocs.
The radius arm bolts on the Defender are M16 but I think are 1.5mm pitch fine thread (not the standard 2.0mm pitch coarse thread). The correct nut for the application is ANR3140, which is a nylon insert nut with a small flange, which will (or at least should) fit the counterbore in the bracket and which look like this:-
If you want to check the thread (I visually checked and it looks to me like 1.5mm pitch) try threading a Defender wheel nut on the exposed end of the bolt, since Defender wheel nuts are definitely M16 x 1.5mm.
There is probably no reason why you should not use an M16 x 1.5mm standard (flangeless) nyloc, but you may find that it is just as easy, possibly easier, to obtain ANR3140.
The corresponding flange bolt, M16 x 1.5mm pitch x 100mm, is RYG501550 should you need it (given that you appear to have non-standard nuts I suppose it is possible that you also have non-standard bolts). As 2016 was right at the end of production, it is possible that substitute parts were used, but the part numbers above are those listed for TD5 and TDCi vehicles. Incidentally they are also used on the P38 and probably many other Landrover products.
Hope this helps.
Post #827585 25th Apr 2020 1:18pm
CarMan
Awesome answer, thanks a lot.
Here is a pic of the existing nut in situ and yes a wheel nut threads on nicely, even if it appears a bit loose on the threads.
In my haste to progress I ordered these earlier, which though a different part number will hopefully be ok Question MOD NOS apparently.
Post #827594 25th Apr 2020 1:53pm
Did those flanged nuts come with the brackets in a kit?
Post #827600 25th Apr 2020 2:30pm
No the kit does not include nuts, just the bracket (the left and right brackets are sole separately for some reason, as if you'd only fit one!)
Carman, assuming that they are the right thread (again try one on the exposed thread before dismantling) they will be absolutely fine, there is no engineering requirement for a flange nut in that application.
Post #827603 25th Apr 2020 2:40pm
CarMan
Perfect Thumbs Up
Post #827612 25th Apr 2020 3:13pm
CarMan
Great tip Blackwolf and of course, they don't fit, as they appear to be the correct size, but wrong thread Evil or Very Mad
Now to find ANR3140 x4 Rolling Eyes
Post #829879 8th May 2020 12:35pm
They are almost certainly a "standard" M16, which will be a coarse thread with 2.0mm pitch. You need a fine thread nut, with 1.5mm pitch. Perhaps inevitably these are harder to find.
M16 x 2.0 fittings are commonly used on towbars, any 2-bolt towball is likely to be secured with them.
Post #829884 8th May 2020 12:57pm
CarMan
From a safety perspective a nyloc is a nyloc right, so as long as it is correct pitch I am assuming it will be safe
I'll get this job done eventually Exclamation
Post #829887 8th May 2020 1:01pm
Yes, effectively all nylon insert stiff nuts ("nylocs") are equal.
Post #829889 8th May 2020 1:06pm
M16 x 1.5 nylocs can be found quite easily. This was the first of many following a search on eBay:
https://www.ebay.co.uk/itm/Metric-Fine-Ext...f1tQ8gdaVw Darren
Post #829905 8th May 2020 2:50pm
