Home > Puma (Tdci) > MY2011/2012 Recall Action P047/048 Front Axle Case
Page 39 of 39 <123 ... 373839
jst
Ianh wrote:
I too would be very reticent in knowingly purchasing a defender that is subject to the recall notice, even if the catch brackets had been fitted. Noting the brackets don’t prevent the axle snapping, just endeavour to reduce the severity of the repercussions of the failure.
However if a failure did occur at speed during a lane change etc on a motorway then their is a risk that a major incident will happen. I doubt if LR have tested that scenario.
It’s one thing to risk your own health, but knowing putting loved ones I.e children etc at risk, even if you deem it a small risk is a big call. Imagine having a conversation with your wife re how much you want a defender, however this one has a known safety issue and you and the children could get injured or die, but there is only a small chance that will happen. So I decided to buy it!!!
Hence I resonate with the decision to look for a defender not subject to the recall, or buying one and replacing with a friction welded axle. Noting even if outside the recall I would (have) fitted catch brackets to a mig welded axle.
So based on that you don't drive a defender unless it has brackets fitted. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1037504 15th Jun 2024 7:38am
TexasRover
It's also reassuring to know that apparently on all those old defender out there you only have to worry about that one point of failure, the axle, with everything else being free of any risk or concern.
Post #1037510 15th Jun 2024 8:37am
itsdashy
United Kingdom 2012 Defender 90 Puma 2.2 PU Orkney Grey
Even though it's a friction-welded axle, I've just had my '12 90 done at Land Rover, Reading. They did it efficiently if a bit perfunctory and it allowed me to sit on the bus for an hour of the day.
Yay for having an extra 3kg unsprung weight that does nothing!
Post #1046037 17th Sep 2024 6:03pm
