Home > My Defender > Our Galway Green Defender 90
Page 8 of 9 <123456789>
sgreenham
United Kingdom 2010 Defender 90 Puma 2.4 HT Galway Green
I can’t really comment on how loud the tyres are as my commute is only about 2 miles on 30mph roads. However on those roads I can hardly tell a difference. I will update once I can get it on different roads.
As it was me that wired up the central locking, it’s probably best I keep the drivers side lock for now Laughing
Post #826954 22nd Apr 2020 5:52am
sgreenham
This is the video on the update of our Defender if anybody is interested. It’s just a roundup of what’s already been shown on this thread...
Post #826955 22nd Apr 2020 5:56am
Badger110 wrote:
sgreenham wrote:
Thanks, they are Goodyear MT/R 235/85R16 on Terrafirma Wolf style steel wheels.
Are the tyres noisy at all?
MT/R's are great tyres but they are noisy above 40-ish mph. I had them on my 110 and I couldn't believe the difference when I changed to some decent AT's. Darren
Post #826962 22nd Apr 2020 7:01am
stephan123
Great thread! You mentioned an airbox modification...could you please elaborate/clarify? Sounds like something I might be keen on Very Happy
Post #827350 24th Apr 2020 11:14am
sgreenham
I think it’s all explained in here... https://www.defender2.net/forum/topic67610...ir+box+mod
It’s essentially removing an plastic impeller on the entry to the air box. Seems to free up airflow a little. It’s a minor step though and you’ll see in the thread that some take it much further by increasing the diameter of the pipe work and it sounds like it makes a big difference.
Post #827377 24th Apr 2020 1:10pm
stephan123
Nice one will try that this weekend. Noticed you managed to get the offending object out in one piece. Any tips on offer? Also what tools would you suggest? A number of people used a dremel but I don't have one. Shocked
Post #827395 24th Apr 2020 3:09pm
sgreenham
I didn’t have to cut mine but it was hard work. I took the top off the air box, removed the filter. Undid the hose to the turbo and moved it out the way. If you follow the pipe that feeds the air box, towards the intake in the wing, there is a fixing that holds it in place, undo that so that it makes that pipe a bit looser. You should then be able to pull the pipe work out of the air box fairly easily, but it won’t come out very far. I then had to man handle it and push it down so it went below the air box allowing me to slide the impeller out. That last bit was pretty hard but doable. It’s also pretty hard work to get the pipe back in again. I didn’t cut the inside of the air box on mine.
Post #827408 24th Apr 2020 4:11pm
stephan123
Thumbs Up
Post #827437 24th Apr 2020 6:15pm
sgreenham
I reassembled the tow bar after spraying it a couple of weeks ago. There was some electrical tape on the cable which I assumed was covering up some connector blocks from where it had been rewired in the past. Oh no... no connector blocks used at all. Just wound together Shocked
Post #827494 24th Apr 2020 9:51pm
sgreenham
After stealing the idea from Stacey007 here - https://www.defender2.net/forum/topic71946...erse+light I too fitted an extra reversing light. Will help especially whilst I still have incandescent rear lights (these will be upgraded to LEDs at a later date). Not bad for £7 we will see how long it lasts.
Post #827637 25th Apr 2020 5:16pm
stephan123
Instructions were spot on! Many thanks. Had to rope in some extra muscle to remove but very happy with the results Very Happy
Post #827762 26th Apr 2020 11:54am
sgreenham
Oh good work!! Thumbs Up
Post #827777 26th Apr 2020 2:27pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
I’ve just found your YouTube channel. Cool
Post #827923 27th Apr 2020 8:24am
sgreenham
Thumbs Up a little like the Landy, a hobby that’s getting out of hand.
Post #827934 27th Apr 2020 9:47am
sgreenham
Bought a raised air intake from a user on here (thanks ‘London 52’). It was difficult to fit the supports to the window frame. There isn’t much room behind there but with the help from the wife we got there in the end. Love the utilitarian look that the Bearmach one gives.
Post #831054 14th May 2020 1:44pm
