Home > Wheels & Tyres > BF Goodrich KM3 MT
Page 8 of 9 <123456789>
Some steering lock stop adjustment. No rubbing and you can’t use chains with 255 but to the vast majority of people that isn't problem. The very very small change in gearing is better I find. WeWillWin🇬🇧🇺🇸
Post #818789 8th Mar 2020 2:39pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
Cheers, thank you.
Sounds like they might be the way to go Thumbs Up
Post #818800 8th Mar 2020 5:19pm
Credit goes to Blackwolf on here as he advised me first and I agree once I had the same that the 255’s are very good in that size. Thumbs Up WeWillWin🇬🇧🇺🇸
Post #818802 8th Mar 2020 5:37pm
db950
The only slight thing that’s puts me off them is the sidewall bulge with them on 6.5” wolfs.
Post #818804 8th Mar 2020 5:56pm
Grouse
db950 wrote:
Thanks, that’s some size difference. Is that against a 235/85/16 ?
Any rubbing in the arches? Steering stops need adjusting? Loss of power with a 300tdi?
Sorry for all the questions but having to buy 5 is a big cost and I don’t want to get it wrong!!
In point form answers are :
1. That is comparing a 265/75 to a 255/85. A 265/75/16 is the same diameter as a 235/85 - the image therefore shows the difference between the overall diameter of the two and is representative of a 235.
2. No rubbing in the arches at all.
3. Slight rubbing on radius arms, either live with it or adjust the stops.
4. No loss in power - however I have the lower ratio 1.6 transfer box and not the 1.4 or 1.2. She zips through the gears and will leave quite a few drivers surprised and will also pull from 25/30 mph in 5th with no labouring
5. She tops out at an indicated 85 on the speedo, but the acceleration for a Land Rover is astonishing due to the high output of the 300 and the lower ratio transfer box
7. The sidewall bulge is fine on the 6.5 Wolf Rims and fall well within the recommended rim size for a 255 2017 Range Rover L405 Vogue SE V8 Diesel #16
Land Rover 110 300 TDI
Post #818824 8th Mar 2020 7:53pm
db950
Many thanks for taking the time to answer my questions, greatly appreciated Thumbs Up
5 x 255/85/16 km3’s now ordered!
Post #818834 8th Mar 2020 9:21pm
Post #818836 8th Mar 2020 9:30pm
Grouse
You won’t regret it Thumbs Up Thumbs Up 2017 Range Rover L405 Vogue SE V8 Diesel #16
Post #818837 8th Mar 2020 9:40pm
I’m still on KM2’s and will be for a long time and very happy with those. In future it will be KM3’s though.
Up until recently I was not holding my breath on ever seeing a 255/85 KM3.
Perhaps the enquiries that I and probably many others have made over a period of time did indeed bear fruit. WeWillWin🇬🇧🇺🇸
Post #818839 8th Mar 2020 9:45pm
db950
Thanks chaps, will be a while until I get them fitted as just starting a strip down and rebuild! Thumbs Up
Post #818841 8th Mar 2020 10:06pm
db950
Fresh rubber delivered today, can’t wait to see these on Very Happy
Post #819131 11th Mar 2020 3:51pm
Post #819142 11th Mar 2020 5:06pm
landy andy
Still got mine in the garage after being pizzed about with the wheels that I was buying. Evil or Very Mad Evil or Very Mad
Post #819172 11th Mar 2020 8:40pm
jst
What sort of money are people getting km3 255.85s for? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #819183 11th Mar 2020 9:37pm
db950
Cheapest I could find them for was £157 each from Camskill, ordered them Sunday and saw on Monday they had gone up to £171 each!
Post #819202 11th Mar 2020 10:26pm
