Home > Puma (Tdci) > MAF and MAP Sensor replacement. |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
As above .. ^ ^ ^
We are looking to do an extended trip in the 110 in the near future and would like to have a pair of sensors(MAF & MAP) as spares We’ve a 2.2 (2012) and have 100,000 miles on the clock now so preempting the possibility or needing to replace the sensors before they let me down ... Does anyone have the ford equivalent numbers for them for a 2.2 ?? Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
21st Feb 2020 10:49am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6621 |
For a 2.2,
MAF LR019380 = Ford 1516668 MAP LR075167 = Ford 1913600 1988 90 Td5 NAS soft top 2015 D90 XS SW |
21st Feb 2020 11:09am |
Superstar ±± Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
21st Feb 2020 11:21am |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2221 |
^^ Martin
My local Ford dealers want £250 for the MAF sensor, £295+ VAT. I nearly fell off my chair. My LR dealer is £150 MAF and £45 for the MAP. Don’t understand all the hype about going FORD at those prices. Keith |
21st Feb 2020 4:16pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20512 |
Definitely different. No Guts, No Glory.
21st Feb 2020 6:03pm |
LR has a lot better parts access than Ford does, I can't stand having to go on the phone and people not understanding what the part is etc etc.
Very little available online for Ford I found. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 Last edited by custom90 on 21st Feb 2020 8:35pm. Edited 1 time in total |
21st Feb 2020 6:37pm |
I didn’t do an online search but phoned 5 different Ford dealerships in the country, they all gave me the same price on the same part No’s.
All the £25’ish fleebay parts are most definitely not genuine but then are they actually any different ? Keith |
21st Feb 2020 7:58pm |
deaallen Member Since: 15 Feb 2016 Location: Basingstoke Posts: 266 |
the Ford one I bought most definitely is genuine
21st Feb 2020 9:09pm |
Thorsen Member Since: 01 Jul 2020 Location: Aberdeenshire Posts: 5 |
Throttle response specially in low rem’s i can push the throttle to the bottom and nothing is happening, sometimes it suddenly comes other times i have to apply the clutch to get the rem’s up when i am on the road doing 60 there is no problem, i have cleaned the MAF sensor and that helped for a bit but the problem is still there any one have a idea
15th Oct 2020 1:47pm |
nicolas0505 Member Since: 23 Dec 2020 Location: briançon Posts: 80 |
About the map sensor references between 0 261 230 132 and 0 261 230 225 which are now 131 and 224 at the end. they are both possible to be mounted.
21st Jan 2021 8:20pm |
orzowei Member Since: 10 Mar 2021 Location: toscana Posts: 14 |
Hi ! Thanks for the info!! much savings! I wanted to know if the replacement of Maf and Map needs updating to the Ecu. Thanks a lot again, Giulio from Tuscany !! |
13th Mar 2021 5:45pm |
No worries my friend, no ECU work required.
Simply fit the parts and off you go, unless you happen to have the amber dash light. If that was the case, you’d then need to have that cleared. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
13th Mar 2021 7:57pm |
Grazie Mille!!! ero convinto fosse necessario inserire i codici deli ricambi aggiornati tramite Obd2!
Thank you so much!!! I thought it was necessary to enter the spare parts codes updated through Obd2! |
14th Mar 2021 6:36pm |
Broonster Member Since: 14 Dec 2019 Location: West Lothian Posts: 23 |
Oh my word.
Okay, so I just cleaned both sensors. MAP was totally covered in crap. It's not totally cleaned, as I didn't want to be too harsh with it, but the difference is noticeable with just the 5 minute clean I gave it. Ultimately I'll just order a new MAP anyway, but even a clean of the existing one shows the need to do this regularly. Love this forum! ‘08 Defender 90 Hardtop |
1st May 2021 1:19pm |
