![]() | Home > Puma (Tdci) > MAF and MAP Sensor replacement. |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 ![]() ![]() ![]() |
Probably not - usual suspect for that is the switch on the clutch master cylinder. Rgds.
Chris |
Willfindlay Member Since: 08 Mar 2021 Location: Yorkshire Posts: 24 ![]() ![]() ![]() |
Great, I’ll get one of them ordered to. Thanks
orzowei Member Since: 10 Mar 2021 Location: toscana Posts: 14 ![]() ![]() ![]() |
quoto pacha e' probabilmente lo switch frizione. a me lo faceva prima di sostituirlo.
https://www.amazon.it/dp/B00BJLH412?tag=am...merReviews
questo e' OK per il 2.4? grazie! |
Sì che è corretto. Darren
Grazie!!
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 ![]() ![]() ![]() |
Just cleaned my MAP this morning, it was covered in muck. Engine runs a lot sweeter now, and some of hesitation seems to have gone.
I replaced the VCV, cleaned the MAF (and ordered a new one from Opie Oils which has not arrived yet) However, the MAP seems to have seriously jumped in price for a genuine Bosch 0261230131 article, looking at over £50!!! Has anyone found a good reputable supplier at a decent cost? Altho the cleaning seems to have helped, I would like a spare on the shelf Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 237 ![]() ![]() |
OMG if you think the MAP is expensive now, try the MAF at almost £100! 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround |
Polarismd Member Since: 13 Feb 2022 Location: Leicestershire Posts: 62 ![]() ![]() |
![]() Click image to enlarge Hi, I found these guys on the web. https://www.autodoc.co.uk/ I put my reg in and then searched for the part numbers on Page 1 of this thread. Apparently these fit 2007 - PUMA. Any comments? Chris ![]() Click image to enlarge |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4255 ![]() ![]() ![]() |
Auto doc have a bit of mixed reputation shall we say when it comes to delivery times and warranty returns. I would only use them as a last resort. 2007 110 TDCi Station Wagon XS
I stuck to more known makes TBH. I have had no real issues with Autodoc providing it is an OEM part. Rgds.
Chris |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20719 ![]() ![]() |
I’ve used Autodoc, no problems but the delivery took rather a while.
The MAP I’d recommend sticking to a Bosch part, the MAF you’d need to find a Ford parts dealer as the source I originally suggested I believe no longer exists. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Hi,
For £70 I will give it a go and give feedback? Or do you advise otherwise. For the Bosch part I was quoted £245 from LR. Chris |
Hi,
For some reason only known to my stupidity I didn't even look on LRCentre or other parts places. I sort of assumed that these would be special sensors (and difficult to get). I constantly amaze myself how much of a dumbass I can be sometimes. Both parts are available at LRCentre with whom I have no affiliation (other parts places are available) at a reasonable cost. Why did LR want to charge so much, do I have "sucker" written on my forehead? - my wife is nodding. Chris |
