Home > Puma (Tdci) > MAF and MAP Sensor replacement.
Page 6 of 6 <123456
Which engine is it for the 2.2 or 2.4?
So long as the Bosch part number on the MAP matches it’ll be fine to use.
The MAP Sensor is readily available online.
The MAF is a bit more tricky, there is the LR part or Ford Part, the latter is much cheaper but again part numbers should match for one or the other.
The Ford parts are more tricky to buy online but you should be able to source with the part number.
On mine I have a Bosch MAP Sensor and Ford MAF, these top parts are a significant sum less that LR parts and yet are the same equal quality. The MAP is a Bosch part anyway, from the Factory it has Bosch and LR Part numbers printed upon it WeWillWin🇬🇧🇺🇸
Post #964163 6th Sep 2022 3:47pm
Polarismd
Polarismd wrote:
Hi,
For £70 I will give it a go and give feedback? Or do you advise otherwise.
For the Bosch part I was quoted £245 from LR.
Chris
Both parts supplied by AUTODOC work and have done for a week of heavy driving. They arrived a day after ordering. No errors reported in the log.
Post #965485 20th Sep 2022 8:46am
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
The below applies to the 2.4 engine
MAP : this has been already clarified being a Bosch sensor as factory fit, with Bosch PN either 0261230131, 0261230132 in early production years and 0261230225, 0261230224 in later years.
MAF : this is more tricky and there is no reference in this thread of the original supplier to LR/Ford. Well, not wanting to fork out the horrendous price LR is asking for this item, having no easy access to Ford parts, avoiding dodgy OEM ones, I started searching for an alternative ... On the original MAF that my Landy left the factory with, there are two PNs, the recognizable Ford PN 6C11-12B-579-AA, as well as AFH70M-54. The latest is a typical Hitachi type of PN, you can google "Hitachi AFH" and you will quickly get convinced that all their MAF PN start with AFHXXX. So I'm happy with Hitachi being the original supplier to Ford/LR for the MAF part. Ordered online on Autodoc website, arrived surprisingly quickly. When comparing both the Hitachi and factory fit side by side, I am totally convinced that Hitachi is the original supplier to Ford/LR for the MAF sensor.
/Mat
Post #989204 17th Apr 2023 11:11am
BrunoJ
Norway 2012 Defender 110 Puma 2.2 SW Keswick Green
Could someone confirm how the MAF part should looks like for 2.2?
Looks like I have to replace it (works, but parameters are out of range, in accordance to LR service).
I found out I have currently already replaced one, Delphi AF10255. While when I search for LR019830, it propose me AF10432. Event visually they are different - my current one has 'square' corners on far end, while from LR diagrams, as well as some pictures of original part looks like one of the corner should be rounded.
I checked in local Norwegian online shops (rather "Norwegian" as one of them is autodoc...), and it looks to me that LR part nr is listed into most of them. At the same time, in one of Polish shop I found info the Delphi one I have currently fits to 2.2 only if chassis is lower than BA99xxxx (I have CA42xxx).
Here is a link into UK page, for reference only, as they show various of available replacements (any recommended brands in addition to the obvious ones like Bosch or Pierburg?)
https://www.autodoc.co.uk/car-parts/oem/lr019830
On this page I see the Delphi one is a different model I have currently installed - number and cove shape.
Post #1030748 6th Apr 2024 6:30pm
Ianh
I can confirm that the MAF for the 2.2 does NOT have a square end, one side is curved on the 2.2.
I can also confirm that having the 2.4 MAF in your 2.2 WILL cause issues , just like the ones you have been experiencing.
Some vendors sell the same MAF and state its for both 2.4 and 2.2. This is incorrect, they are different.
There is another topic on here where another member had an issue with a 2.4 MAF fitted to their 2.2, I can’t find it at present but will add a link if I find it.
Post #1030778 6th Apr 2024 10:06pm
BrunoJ
Thanks a lot for clarification. I'll replace it with rounded one.
Post #1030780 6th Apr 2024 10:10pm
TriniDaddy
2008 Defender 110 Puma 2.4 XS CSW Arles Blue
Thank you so much for this!
I know it's been some time on but I've managed to source the MAF sensor and I hope the correct MAP.
Knowing the connection to these sensors and the Limp mode issue, would the same approach be reasonable to change the throttle position sensor (throttle potentiometer) with the transit version as well?
Not convinced that's malfunctioning but if that turns out to be the case, are they identical? 110 SW 2.4
IZUMI BLUE
Post #1061448 26th Feb 2025 6:43pm
I’d leave the TPS alone, unless you get a system DTC suggesting it’s logging a DTC personally.
Issues with that are a little more common on 2.2’s as well.
That’s just my views.
Mines running well on the sensors I replaced, at the time I did that due to age, but now onward biannual cleaning with brake cleaner sorts them out.
The MAP is more likely to get gunked up I find, but if you do have an oiled air filter, then,
regular MAF cleaning to mitigate oil contamination is a good idea.
I use the Genuine air filters, so I find that’s not an issue.
There are lots of options with air filters etc out there now.
Thumbs Up WeWillWin🇬🇧🇺🇸
Post #1061460 26th Feb 2025 9:37pm
Shafski
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
If it helps.
I’ve just replaced the MAF on my 2.2 with this. Direct fit, £78
I also bought the MAP, not fitted yet for £18, also from same place, Bosch again;
Thumbs Up Shafski
_________________________________________
2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E
Post #1061492 27th Feb 2025 7:07am
TriniDaddy
Thumbs Up
Man thanks again Martin! Got both sensors on Saturday. The MAP had some damage (the little plastic around the leads was broken). Fitted the MAF first and got temporary relief until a couple miles drive (it's been extremely hot these days) the limp mode came back along with the temp gauge going all the way up, loss of power etc. At the side of the road I just put in the MAP and presto! Running stable and smooth. The overall power is a bit more torquey but I don't mind that.
Will get a scan done tomorrow and see what else has the engine light on. Might have an issue with the AC evaporator. 😤
Also going to change the engine seals rocker cover, injector etc. Getting an oil leak off the sides again. I suspect the ECU had it overworking a bit and found a weak spot. Will see. 110 SW 2.4
IZUMI BLUE
Post #1063215 17th Mar 2025 11:54pm
TriniDaddy
Shafski wrote:
If it helps.
Thumbs Up
Got these
MAP $13USD: https://www.amazon.com/dp/B0D9N4JNSZ?ref=p...asin_title
MAF $18USD: https://www.amazon.com/dp/B08ZN72QM8?ref=p...asin_title 110 SW 2.4
IZUMI BLUE
Post #1063217 17th Mar 2025 11:59pm
TriniDaddy
Ok. "Didn't work". Got the MAF from Amazon. Great price and delivery but the one sent is a 6 pin and the unit from the car is a 4 pin.
I'm sure that's making all the difference.
Car was driving great while it was working though... 110 SW 2.4
IZUMI BLUE
Post #1063311 19th Mar 2025 2:36am
Page 6 of 6 <123456
