Home > Maintenance & Modifications > Recall Number: P022 Park Brake Oil Contamination
Page 6 of 7 <1234567>
bob neville
Looking at the amount of oil that has leaked out overnight I think I will be pushing for a new transfer box. It also looks like the seal on the rear diff may also be leaking, no problems before the recall, but I can't confirm that due to the amount of oil that has sprayed everywhere.
I will let you know how I get on.
Bob
Post #72072 22nd May 2011 8:54am
bob neville
Quick update.
Told not to drive vehicle until LR Assist have had a look. Dealer is concerned that the transfer box may seize.
Assist coming at 6am Shocked Tuesday and vehicle will be either driven or recovered to dealer.
Bob
Post #72254 23rd May 2011 12:13pm
bob neville
Vehicle at dealers now, driven in after LR assist checked transfer box oil level and deemed OK to drive - have the written evidence for later use if needed !
New transfer box seal replaced as part of the recall was faulty and failed after 20 miles.
Seal being replaced, transfer box has been checked and is ok.
Somehow the rear diff seal was damaged whilst doing the recall, new seal arrives Wednesday.
Bob
Post #72497 24th May 2011 3:00pm
BigMike
christ bob, this isn't good. your dealer seems to be totally incompetent.
Post #72501 24th May 2011 3:07pm
Happyoldgit
How the hell did they manage to knacker the diff seal? Makes you wonder if the first transfer box seal was faulty or they made a cods ear of it. Steve.
http://forums.lr4x4.com
Post #72515 24th May 2011 3:47pm
bob neville
I think the latter ! All I know is that they did take the rear prop off, new bolts front and rear, probably used a club hammer to put it back on and destroyed both the seals.
BigMike
They appear to be now. They used to be exceptional but the standards have slipped recently - I did see them advertise for mechanics a short while ago so my guess is all the best ones have moved on. The dealer principal knows that I don't call LR customer service, I go directly to the executive office, so I am sure it will be OK when it comes out - famous last words !
Bob
Post #72521 24th May 2011 4:03pm
bob neville
All fixed Thumbs Up
The new seal fitted to the transfer box under the recall was faulty and they have no idea why the diff seal started to leak as well.
Guess they would never own up to a bodged job so we will never know the truth.
Bob
Post #72941 26th May 2011 7:08pm
bearman
South Africa 2008 Defender 110 Puma 2.4 SW Alpine White
Bob
Big Cry Same here 3 days and 73kms after recall done - new seal gave up sealing - dumped oil all over the show.
Post #73864 2nd Jun 2011 1:59pm
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
i've phoned LR and cancelled my appointment, too scared they break something - my brake seems quite fine, i'll take my chances without the recall work... www.ralton.co.za
Post #73866 2nd Jun 2011 2:07pm
MK
I would do the same. Just give me the parts...... Puma 110" SW
Post #73873 2nd Jun 2011 2:42pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
mine went in yesterday.
new seal, re-fitted brake shoes.
i also asked them to check on a conk when changing gear. diagnosed as loose bolts/nuts on the brake drum. clonk now gone and the drive is smooth again.
so far no signs of an oil leak - i will keep checking, my drive was/is clean of drips so it should be easy to check if it starts leaking Confused BM52
Post #73887 2nd Jun 2011 5:47pm
adiep
Gibraltar 2008 Defender 110 Puma 2.4 SW Alpine White
Re: Recall Number: P022 Park Brake Oil Contamination
Lorryman100 wrote:
Recall Notice: P022 Park Brake Oil Contamination
Date of Issue: 22nd February 2011
VIN Range: LD066843 – LD071690 (CKD) LD730411 – LD823248
A concern has been identified with the park brake fitted to 2007-2011 Defender vehicles. Any vehicle repaired under Recall Action P019 prior to the revised repair procedure identified in bulletin P019v4 must be recalled and repaired under this campaign. The shoes of the parking brake could be contaminated with oil which has leaked from the rear of the transfer box. Where oil from the transfer box has impregnated the park brake shoes, the park brake may not hold the vehicle when the park brake lever is applied and the vehicle may instantaneously roll. Transfer box oil contamination of the park brake shoes and brake drum leads to a loss of friction between the brake shoe lining and the brake drum friction surface such that the park brake drum when engaged will not hold the vehicle stationary on a gradient.
Action to be taken:
Land Rover has taken the decision to recall affected vehicles to remove the output shaft flange, clean the splines, apply Loctite 648 and where necessary and the brake shoes will also be replaced.
I logged into Topix and says my car has this announcement... Does this work get carried out free of charge even if outside of warranty?
P022 - PARK BRAKE OIL CONTAMINATION
Post #191966 9th Dec 2012 8:07am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
i hope so as mine still needs doing
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #192680 11th Dec 2012 11:59am
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
I have noticed this problem. Is it only repaired in the guaranty periode or also when the car is out of waranty?
Q.
Post #800468 2nd Nov 2019 2:00pm
MK
In my case (Chile) I received an email from the dealer long after the warranty period. Puma 110" SW
Post #800470 2nd Nov 2019 2:05pm
