Page 1215 of 1379 <123 ... 121412151216 ... 137713781379>
L110CDL
AJC wrote:
we set off to Scotland Thursday so thought I'd hoover it out so its nice and clean for the trip, this ended up being a full days cleaning, polish, wax, all glass sealed etc. Looks bloody good for it and don't need wipers anymore!
Looking really nice there AJC Bow down
What did you use to seal the glass please Question
I will be giving Millie a good clean inside and out, a week Friday weather permitting for our trip up north Wink 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #788097 21st Aug 2019 7:39pm
MussEd
Scotland 2013 Defender 110 Puma 2.2 USW Baltic Blue
Today I took a blow torch my hub nuts and replaced them with nice SS ones, then took my car to have the steel wheels powder coated. My plan was to paint the hubs before this but my factory LR jack packed in on its first ever use last night so ran out of time today.
Post #788121 21st Aug 2019 8:43pm
Huttopia
I took the 110 to a bodyshop in Redditch to have the little 'bump in Bremen' sorted out, then drove the 90 to St Albans - I was just about to set off and a delivery driver turned up with the new air filter valve / bung so I fitted that. The old one was perished - and absolutely disgusting - a thick coating of oil / grime on it. I checked the air filter I fitted a week or so back and its fine so I assume the grime on the valve was from historical leakage!
The engine has started dripping a little bit of oil again, so more investigations needed. The gift that keeps on giving. Rolling Eyes
Post #788174 22nd Aug 2019 7:14am
williamthedog
Stainless Steel isn't really suitable for holding the drive flanges on. They've got to be high tensile, 10.8 I think.
Post #788223 22nd Aug 2019 10:31am
Are they stainless or BZP?
As far as I can see from zooming in, they seem to be head-stamped 10-9 in which case they are ideal.
(The normal grade for a hex socket head capscrew is 10.9, which is the correct spec for the drive flange bolts).
Post #788233 22nd Aug 2019 12:08pm
MussEd
They are A4-80 which I thought suitable for this task? Please tell me this doesn't mean I need to get the blow torch out again for the copious amount of threadlocker I used yesterday!
Post #788264 22nd Aug 2019 3:03pm
v8steve
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Rimini Red
standard cap screw are 12.9 grade. standard flange bolts 10.9.
cap screws in pic look like a4 70 or 80so not as strong and easier sheared
just saying Whistle 110 xs s/wagon
s3 swb soft top
Post #788284 22nd Aug 2019 5:33pm
I’d say that’s a recipe for a bad day.
Post #788302 22nd Aug 2019 7:12pm
RILEY
United Kingdom 1994 Defender 90 Td5 CSW Stornoway Grey
go easy on the clutch Rolling with laughter one life, sell it
Post #788322 22nd Aug 2019 8:33pm
excossack
Yesterday extended the control panel wires using thinwall 7 core trailer wiring.
Today i got the fuel line ran from the engine bay to the heater and attached the inlet pipe and exhaust.
Air intake i think i am happy with, not 100% sure yet on the exhaust routing.
 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #788470 24th Aug 2019 12:15pm
In that case I'd replace them as soon as possible with grade 10.9 or higher HT bolts. There are two major problems with A4-80 in this application; firstly they lack the tensile strength and ductility of the originals, meaning they are far more likely to shear, and secondly unless you used an anti-seize paste such as Weicon they are likely to cold weld themselves into the hub. Neither eventuality is good.
Worst case may be that you already cannot remove them, I'm afraid. I have before now had an A4 screw weld itself into a nut before it was even tight. Horrible things, stainless fasteners! Personally I avoid them like the plague unless essential, and then use copious amounts of Weicon.
Post #788473 24th Aug 2019 12:44pm
90 Dreamer
Out and about doing some messages and just because............
Post #788491 24th Aug 2019 5:36pm
Went up The Peaks.
The early One Ten was utterly ‘my bag’.
Surprisingly HOT, but very little traffic, on 4 & 2 wheels, as well as 2 feet and 4 hooves!
The L200 was driven by a girl who’d NEVER been off-road before..... she is now a ‘vet” at it.
Post #788588 25th Aug 2019 6:49pm
Slideywindows
That's a nice straight-looking early One Ten slidey-window hard top.
Not so many Y platers still around, can you tell us any more about it Greeni?
I guess from the vent in the wing that it's been Tdi'd, has the owner kept the original engine?
Post #788604 25th Aug 2019 8:06pm
Yeah it has a 200 in it. On a galvo too!
Not sure about the og engine.
I LOVED it, but what was most impressive, it’s the first vehicle he”s ever bought.
I hope he never sells it.
He was 3 up across the front seats, with missus and teen (i think) daughter!
Not all heroes wear capes.
Post #788630 26th Aug 2019 7:06am
