Home > My Defender > An Anorak's Utility Station Wagon |
Ha, ha, the jury is still out on that one Darren
22nd Jul 2019 11:42am |
When I first bought this vehicle, it was fitted with a Mota Lita steering wheel, which I hated:
Click image to enlarge I changed it as soon as I could for a standard wheel which, all other things being equal, I was very happy with: Click image to enlarge However, in a bid for greater security, I decided that a removable wheel would be a good idea. Unfortunately though, the only aftermarket wheel that I'd consider is the Startech and the huge cost meant it hadn't reached the top of my personal priority list yet. Then, by chance, I came across a brand new one being sold on eBay and a cheeky offer secured it for half price. Happy days I haven't got the removable boss yet but I couldn't resist fitting the wheel. With the old wheel removed, I offered the new one up and it was immediately apparent that it wasn't a straight forward fit. The boss on the back of the wheel was fouling the raised lip on the plastic column cowl. A few minutes with a small razor saw reduced the lip by a few mil, allowing the wheel to fit properly: Click image to enlarge The new wheel was then offered up and, having checked that it was square, was marked to aid removal in the future: Click image to enlarge And the finished article with the centre cover and Land Rover badge in place: Click image to enlarge Having driven Land Rovers of all shapes and sizes with standard wheels for over thirty years, the smaller size will take a bit of getting used to but it does feel very nice. One thing I didn't realise until I was driving is that I've lost the self-cancelling indicators, as the boss doesn't have any pins to trip the mechanism. I'll live with it for now as I'll swap it again when I get the removable boss, hopefully in a week or two, which I believe comes equipped with the appropriate pins. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
27th Jul 2019 8:58pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5160 |
A fellow 306 owner came over to pick some parts up, he likes defenders too. he noticed the wheel was missing on mind. He said what's the story with that? I told him this is what we have to do now, he couldn't believe it how bad these were for been nicked.
The star wheel I do like, but I wasn't willing to pay for the wheel and the odd layout boss either, when I can put the money towards something else on where the car needs it. Plus the option I have gives me more of a choice of wheel. My dad wont switch at all to one. He is happy to keep the disklok. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
28th Jul 2019 12:56am |
Another day, another security layer This time, it's the X-Defend column lock produced by X-Eng, which is basically an armoured sleeve for the ignition barrel. This is a great security measure as it's completely passive and doesn't require anything to be locked, unlocked or stowed when not in use:
Click image to enlarge It's clamped in place by the M12 bolt, visible on the top, above. The clever part though, is that it's a shear bolt and once fitted, it cannot be removed without a lot of effort. Fitting is more fiddly than difficult. The first step is to remove the plastic shroud around the steering column. It's easier to remove the steering wheel first and then it's just a case of undoing six screws underneath. Of course, being a Land Rover, there are two different types - four posi and two torx on a Puma The hole for the ignition barrel needs to be enlarged to accept the sleeve, from 30mm to 36mm. I very carefully used a step drill for this. The dimension isn't overly critical though as the opening is covered by the blue anodised aluminium securing ring: Click image to enlarge The top part of the plastic shroud also needs to be trimmed to clear the top of the sleeve when in place. The picture below shows what I've trimmed off. This is completely hidden under the instrument cluster when fitted. Click image to enlarge With the immobiliser energiser ring removed, the X-Defend is fitted over the ignition barrel with the securing bolt facing forwards. It's in position when the face of the barrel is pretty much flush with the inside of the sleeve. It'll only really fit one way: Click image to enlarge The energiser ring needs to be secured out of the way but still near to the ignition barrel so it detects the key fob. Space is tight and I faffed around with this for a while before eventually cable-tying it to the bottom of the steering column, as far forward as it would go which just allows enough clearance for the two white connectors to fit back inside the column shroud. Forgot to take a picture of that bit though, unfortunately I kept testing the ignition during this process, to make sure that the immobiliser would disarm properly! With the top and bottom parts of the column shroud back in position, all that remains is to fit the aluminium securing ring, which only needs to be finger tight as the thread is also quite tight: Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
28th Jul 2019 7:44pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4795 |
Interesting write up 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
28th Jul 2019 7:50pm |
I am toying with this idea of the next security on mine, Are these easier to do on the TD5 than the puma? I may look into one for my dads 200. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
29th Jul 2019 12:40am |
Installation on a TD5 is virtually identical. From memory, I think there's one more screw on the bottom of the steering column shroud and probably a different mix of types
Here's a copy of the fitting instructions: https://www.defender2.net/gallery/albums/u...ctions.pdf Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
29th Jul 2019 6:08am |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 |
i remember doing mine, and its a very good fit over the barrel, at first you don't think it will fit but it's snug which is a good thing.
29th Jul 2019 11:36am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20302 |
Pity there isn’t an OBD lock for that connector too. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
29th Jul 2019 2:56pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17354 |
OBD socket locks are available and are very high up my list of essential security upgrades.
29th Jul 2019 3:43pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2142 |
Why do you need that??
29th Jul 2019 6:52pm |
Because unfettered access with the right kit allows all sorts of things, such as the ability to programme new key fobs or deactivate security. Darren
29th Jul 2019 11:38pm |
If you think about the sequence of operations needed to steal a Defender, then step one is to gain access to the vehicle, step 2 is to get into the vehicle, and step three is to spirit it away.
Step one can be made harder by keeping it in a locked garage or the lion enclosure at your local zoo. Step two can be made harder with better alarms, relocating the BBUS, etc., but the sad fact remains that the vehicle structure remains extremely insecure and ones the alarms have been overcome, getting in takes seconds. Step three can be made harder by a removable steering wheel, pedal locks, wheel clamps, hydrualic locks, parking bollards, etc, but if it is to be driven off then at some stage the passive and active immobilisers will need to be overcome. There are several ways to do this, but most methods (but not all) involve accessing the OBDII socket. So, in my book, disabling the OBDII socket in some way is just another essential layer of security. |
30th Jul 2019 7:19am |
so its a bit like the later BMW's (and probably others) where you can actually recode a new key even when you dont have the original...........will get something sussed - cheers
30th Jul 2019 7:38am |
