Home > Maintenance & Modifications > LOF POWERspring pedal assist
Page 8 of 14 <123 ... 789 ... 121314>
I fitted one of these springs on Saturday and it was, frankly, a bit of a challenge.
More details here: https://www.defender2.net/forum/post782396.html#782396
On the plus side, having now driven with it for a couple of days, I'm on the verge of declaring it my best mod yet, such is the impact it's had Shocked Darren
Post #782518 22nd Jul 2019 10:38am
Matt
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Fitted my new spring today using the cable tie technique and successfully finished in 15mins including cutting the bit of wood to prop the pedal!
I do have a bit of a problem though.... makes the pedal feel much lighter, but when pressed all the way down the pedal feels like it over centres and gets stuck in the down position. When you lift your foot off it takes a fraction of a second for the pedal to come back from being stuck.
Any ideas???? 15 plate 2.2SW XS
Post #783108 25th Jul 2019 7:18pm
Bluest
Not really helpful, but mine feels like it is about to do what you describe, but hasn't ever actually stuck down. 2007 110 TDCi Station Wagon XS
Post #783109 25th Jul 2019 7:20pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Any ideas????
Sounds like you’ve fitted it upside down. Look at LOF website. I did the same 😂
Post #783140 25th Jul 2019 9:21pm
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Hi Matt
I also fitted one this evening in my 2015MY SW XS and have exactly the same feeling through the pedal as you describe.
I don’t think I have fitted it upside down but will take a look tomorrow.
Post #783157 25th Jul 2019 10:13pm
Can I suggest living with it for a day or two? When I fitted mine. I found that I was applying far too much pressure, which made it feel as though the pedal was stuck down when releasing the pedal. After driving round for a few days though, I re-learnt what was required and now it's great. Darren
Post #783160 25th Jul 2019 10:50pm
Matt
Can’t see how it can be installed upside down, this is how it looks:
Will give it a few days and see if it wears in a bit.
Took my foot off the clutch last night going home and the pedal stuck down, had to use my toes to pull it back up 15 plate 2.2SW XS
Post #783186 26th Jul 2019 8:39am
X4CAC
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Will be interesting to see the how other folks with later models get on with... I appear to be the only person as far as I've read that hasn't noticed the spring making any difference at all... Shocked
Post #783187 26th Jul 2019 8:46am
Sulisuli
2015 HT 90 and yes I have noticed a difference, you can’t measure the difference and maybe some of it is physiological but SWMBO drove it and noticed it was lighter compared to her 90 Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #783193 26th Jul 2019 9:06am
Perhaps the plastic U bush isn't seated properly and is catching on the edge of the matting? Might be worth an explore with the pedal pushed down. Darren
Post #783337 26th Jul 2019 10:30pm
Matt
I squirted some spray copper grease around the plastic bushes yesterday which seems to have helped this morning when I took the Land Rover out. I’ve checked the bushes to make sure they are all seated correctly, the only thing I can think of is that the spring seemed quite a tight fit in the two round bushes when I practice assembled it before installing it on the pedal. I wonder whether there was a slight manufacturing fault or intolerance which hopefully will wear in that has caused this issue. 15 plate 2.2SW XS
Post #783394 27th Jul 2019 11:19am
Ndamico
Canada 2004 Defender 110 Td5 CSW Alpine White
I just installed the spring today and mine does the sane thing. its not backwards. it feel great until just before it hits the floor and then it feel as if it goes past center just a hair and wants to stick to the floor. i've lubed the bushes too.
Post #783640 28th Jul 2019 6:19pm
Matt
I’ve been using the defender all weekend and I have to say it feels much better now, the pedal hasn’t got stuck down since Friday evening and now my foot has got used to the light feel it’s a massive improvement over the standard spring, considering I have serious left hip problems.
I would suggest giving it a few days and see how you get on with it after it wears itself in and you get used to the pedal feel! 15 plate 2.2SW XS
Post #783642 28th Jul 2019 6:26pm
Sulisuli
Good news your feeling the benefits now. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #783683 28th Jul 2019 9:15pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Luke fitted mine at the kelmarsh show yesterday and have to say wow what a difference
Easily as good as the red booster I had on my old one and a fraction of the cost 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #783693 28th Jul 2019 9:55pm
