![]() | Home > Maintenance & Modifications > LOF POWERspring pedal assist |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 748 ![]() ![]() ![]() |
Fitted mine using the cable toe technique. Also bent the two flanges in slightly so the ends of the spring go through enough. Spring was moving to one side and I could not see the end of the spring past the plastic insert. Gave it a good squirt of white grease. Felt a bit sticky when pressed but after a few days that is no longer the case. I think I was over exerting pressure on it to begin with. Noticable difference......
RANGER1312 Member Since: 04 Feb 2018 Location: Fylde Coast Posts: 125 ![]() ![]() ![]() |
I know this is going to be a stupid question and I’ll pre-warn you that I’m not mechanically minded however I’ve purchased one of these and like most on here struggling to get it on so...
Got me thinking, I though clutches themselves have springs in them and once I removed the LR spring from the clutch pedal and the pedal works as normal so why not just remove the old one? Is the clutch pedal spring just to stop rattles? Only asking as I’ve had to move the Defender without the new spring in and it drove fine ![]() |
Managed to get it on, wow what a difference!!
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4800 ![]() ![]() ![]() |
Glad you got it fitted ok
![]() 2008 SVX 90 2000 XS TD5 90 |
Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 262 ![]() ![]() ![]() |
Just an update on my findings after having the spring fitted for just over two weeks and a short 500 miles.
The pedal did get stuck down once or twice in the first week but now I have got used to the lighter feeling pedal it’s not really been a problem. I have to agree it feels much better now and an improvement over the standard spring, with the added bonus of smoother gear changes. I would also suggest that you giving it a few days and see how you get on with the new pedal feel! |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1369 ![]() ![]() |
Has anyone left the horse shoe bush off the back of the clutch pedal? I can’t get mine to slide all way down the recess in the clutch arm.
stephan123 Member Since: 18 Mar 2015 Location: London Posts: 285 ![]() ![]() |
Had one fitted over the weekend to MY2015 truck. Noticeable improvement. Makes for smoother gear changes and I find it really compliments my ECU remap and slickshift. Well worth doing. On a side note i found the clutch pedal did initally have a sticky feel becasue i was pressing too hard. Soon got used to it and no issues since
Tegner Member Since: 31 Jul 2018 Location: Alnwick Northumberland Posts: 198 ![]() ![]() ![]() |
Had mine fitted this morning by Mastora Alnwick what a difference (couldn't fit due to arthritis)
One of the cheapest and best mods I have done, such a noticeable difference between driving mine with it fitted and the wife’s which doesn’t have one
Not sure how you guys managed to fit this, but I dropped by my indie this afternoon because he was excited to fit one.
90 min and much swearing later, we admitted defeat and put the old spring back in ![]() the plan is to remove the pedal box and then fit it on the bench, unless there's a foolproof way to do it in situ? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
I needed a metal tye wrap and a vice to squeeze it in.
Plastic tye wraps just snapped. |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
I’ve a LOF clutch fitted and the pedal is really nice on its own
Many, many cable ties later, the workshop finally got it in!
![]() Click image to enlarge Big difference to the clutch action, well worth the 20 pounds ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 ![]() ![]() |
I have a very heavy duty clutch fitted due to an engine power upgrade, have the LOF spring AND a servo fitted, still a heavy clutch, but almost solid without them! 80" 1948
Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
