Home > Maintenance & Modifications > LOF POWERspring pedal assist
Page 3 of 14 <123 4 ... 121314>
landy andy
gilarion wrote:
Quote:
What is the difference between this LOF and? DA1266.TR at £14 inc VAT? (Apart from colour?)
I have the LR version fitted and the same thing with left knee problems. The spring mod although helps it is still sometimes painful to depress the clutch pedal. I thought when reading the description on the companies web site that this LOF spring was the solution, I know do not think so. So It might be that the Red Booster is the only solution, however, I will wait to see more reviews on this thread to see what others think once they have fitted the LOF spring.
Got to be worth trying for £25
Post #762695 9th Mar 2019 6:27pm
landy andy
I want a lighter pedal than my standard due to driving different vehicles. I find it difficult to swap to something with a very light clutch after driving my Def all week, especially when I had the old straight spring on it.
Post #762696 9th Mar 2019 6:30pm
Sulisuli
Royo would be interested to try this at the Easter meet if I may please........more expense coming Rolling with laughter 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #762714 9th Mar 2019 8:57pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
So all you guys who have fitted them; what’s the trick to making th e job easy...?
Post #762723 9th Mar 2019 9:54pm
lordackers
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Bonatti Grey
Did mine this afternoon, got this from another site 😳 I used a vice to close the spring then two tie wraps one on each side on the straight bits to hold in place, with the pedal up align the two ends into the side bushes and was a then depress the clutch and secure with something I just used a piece of 3x2 cut to length wedged against the seat. align the closed end of the spring with the catch at the back of the pedal, then cut the tie wraps, I used a knife as I found the snips were awkward to get in. it’s important to get the back lined up as near as possible with the back bush, ideally within it otherwise it doesn’t locate properly and springs off,
Took me about 10 attempts but I reckon now I’ve done it, I could do it again first time
The result? defiantlay less resistance, not massive but definitely easier, will know better on a longer run as was late for work so only had time to manoeuvre back onto the garage
Edited to add pics, of the old spring but should give you an idea
 If I get everything done that I need to do today I’ll be amazed....
Post #762734 9th Mar 2019 11:19pm
deaallen
United Kingdom 2012 Defender 90 Puma 2.2 SW Santorini Black
I wish I had seen that way of fitting with the zip ties before messing around with mine! I'm slightly worried I may have deformed mine trying to get it in!
Does your have a sharp increase of resistance towards the "top" of the pedal press like mine?
Post #762766 10th Mar 2019 11:26am
lordackers
Deaallen,
Not sure bud will let you know when I get chance for a decent test drive
Ackers If I get everything done that I need to do today I’ll be amazed....
Post #762768 10th Mar 2019 11:51am
Lwb97
Wales 2002 Defender 90 Td5 HT Oslo Blue
Fitted mine today on my td5 replacing the lr spring. Definitely worth the money. Pressing the clutch pedal now is effortless. Very happy Very Happy
Post #762837 10th Mar 2019 9:11pm
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
More than happy for you to have a go at the meet. Thumbs Up 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #762850 10th Mar 2019 10:23pm
Sulisuli
Thanks Roy will be very interesting to feel how different it is Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #762852 10th Mar 2019 10:33pm
bankz5152
Just fitted Lukes new spring. Its brilliant.
I had the Britpart one in before to replace the older top mounted spring, i was happy with that but bought the POWERspring on a punt, differencd is even more! The weight reduction is as advertised! So much lighter now! I would suggest it!!
Post #763529 14th Mar 2019 10:54pm
Co1
10 minutes to fit is utter horse sh*t! Been at it for an hour and not further on. Any hints?!
Post #763783 16th Mar 2019 2:36pm
Co1
Sorted. Brute force and ignorance won the day.
Post #763788 16th Mar 2019 3:19pm
gilarion
Love your carpentry skills Co1 and choice of timbers as per the photos on your Instagram account Thumbs Up For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #763801 16th Mar 2019 4:13pm
Co1
Thanks Gilarion, much appreciated.
Post #763803 16th Mar 2019 4:15pm
