![]() | Home > Maintenance & Modifications > LOF POWERspring pedal assist |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3483 ![]() ![]() ![]() |
Mine felt like that but bedded in quickly and felt more natural 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
What is quickly? I've had the same feeling for more than half a year. a defender from 1984 pretending to be a puma with a touch of Range Rover
They all do that - it's inherent in the design - but most people just get used to it. Darren
Just my luck that I'am such a sensitive guy......
In other words I haven't gotten used to it yet. Let's give it another half year and worst case I just remove it. a defender from 1984 pretending to be a puma with a touch of Range Rover |
* Double post * a defender from 1984 pretending to be a puma with a touch of Range Rover
Landowner Member Since: 06 Jan 2023 Location: Somerset Posts: 79 ![]() ![]() ![]() |
Hi
I read conflicting info here, or perhaps the conflicting info is not about the lof spring but the mc? Would the 2.2 Puma benefit from the lof spring? The one already fitted looks similar so I’m guessing the lof is a copy, but does it’s tension differ such that an improvement would be noticed? I guess in short, are people fitting it to the 2.2 Puma? Sorry to drag up such a debated subject again. |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3664 ![]() ![]() ![]() |
I think it is a case of giving it a bit of time and getting used to the difference, for me it has worked and my aching left knee is now complaining much less since I fitted mine DEFENDER 90 TDCI XS,
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 511 ![]() ![]() |
The LOF spring is a stronger version of the Land Rover genuine spring so can be fitted to all models from 300tdi onwards |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1866 ![]() ![]() ![]() |
Finally got round to fitting my pedal spring yesterday lunch time, having watched Luke's fitting video, and convinced it would be done in double quick time, and still time left for a sandwich.
Original spring came straight out, U bush crumbled, tools assembled and found an L leg from my wife's gridwall system the perfect length for holding the clutch. 40 mins later I admitted defeat, rang my brother to ask if he could bring some needle nose mole grips home from work to drop in on his way past, and went and made a consolation sandwich, and further reading of this thread. Stumbled across Roger's very informative post with pictures and decided cable ties was the answer, but with out the immediate access to a vice/quick clamp jury rigged a bar and 3 screw drivers to compress the spring to get zip ties in place. That eventually had to wait until my brothers arrival, where we then fought the spring for another 20 mins before giving up as the zip ties weren't up to the task. My brother then went back to the brute force method, and 25 mins later it finally went in. The difference is immediate, and when I eventually convince my wife to give driving the Defender another go, she'll find the clutch is much lighter. I'd even go to say that the old Fiesta she used to drive has a heavier clutch. Wish I'd done it months/years ago (and paid someone else to do it) 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
cjasmith97 Member Since: 02 Jun 2024 Location: South Tyneside Posts: 4 ![]() ![]() ![]() |
I tried for hours, and in the end just got a local garage to sort it.
No regrets |
shaynecm Member Since: 10 May 2024 Location: Norwich Posts: 63 ![]() ![]() |
I have the PowerSpec Master from LOF and found it didnt work with the spring as well - have the spring in the cubby box just incase of issues but running mine without a spring currently and is great.
just incase anyone buys the power+spring kit. |
