Home > Puma (Tdci) > New MY2011 door uderseal, who know more than me???
Page 5 of 8 <12345678>
bob neville
Thanks for that Zag - at least I now know it is not just something I did incorrectly.
The new seals certainly do the job and the good news (?) is the one that has deformed needed to be refitted as it was not forming a good seal on the bottom of the door. I drilled new fitting holes for the second one put on and that one does keep the water out - so far Laughing
Bob
Post #78093 27th Jun 2011 7:50pm
Froogle-Yorkshireman
2010 Defender 110 Puma 2.4 USW Stornoway Grey
Nightmare Bob Sad Proud owner 110 Utility XS
Ex RR Sport HST V8
Ex Td5 90
Post #78102 27th Jun 2011 9:42pm
bob neville
Froogle-Yorkshireman wrote:
Nightmare Bob Sad
Yep - you learn something new everyday.
Ordered up a replacement last night. Took the deformed seal off by unclipping it from it's fixings and cleaned off all signs of Waxoyl. Overnight it had regained 90% of it's shape. I'm going to experiment with it to see if I can cut new holes in the rubber to get a better fit where I know there was a slight water ingress - just so happens the ingress was where the rear water drain is and also where the rubber deformed badly, maybe a weakness ? If the mod works it will save me having to drill new fixing holes to get a better seal.
Bob
Post #78244 28th Jun 2011 5:44pm
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
Done my front doors today, as well as a bit of a clean up, apply cavity wax and fit the seals.
They do fit on a TD5 too, look smart.
I applied a bit of silicoln seal to the back just to make a double sure seal.
Post #79618 9th Jul 2011 2:42pm
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
My new seals arrived last week!
Next week during my vacation I'll do the work. Matteo
Defender 110 Td4 SE MY 09
Post #81203 20th Jul 2011 4:04pm
nikojo
What model year were these seals used??
I'm looking at a 2010 long distance and don't know which seals it has.
Post says 2011 but can they be applied to 2010 without much work??
Thanks for any help
Post #83327 7th Aug 2011 3:27pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
what size are the holes required?
Thanks
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #83768 10th Aug 2011 5:40pm
bob neville
The holes for the new seal studs are very slightly larger than the original fixing holes, 1 or 2mm tops.
To make the seal effective do not try and reuse the original fixing holes, especially at the back, the new seal needs to be taught. On my o/s rear, the first one I fitted, I just used the orignal holes and there is not enough tension to stop spray ingress. This one needs to be refitted properly. On the n/s rear I had to drill three new fixing holes and it is perfect.
Of course your vehicles may be different so try before you drill Thumbs Up
Not a hard or long job but a little bit of trial fitting and checking pays dividends.
Bob
Post #83804 10th Aug 2011 8:26pm
draymond
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
I'm not sure if it's possible, but wouldn't it make more sense to poke new holes in the rubber seal, and re-seat the fixings than drilling more holes in the door considering they're made of Steel and the risk of rust? Confused
Tell me if I'm way off......
Post #84613 16th Aug 2011 12:58am
nikojo
Why didn't I think of that....... Idea ..........BRILLIANT!!!
Post #84615 16th Aug 2011 2:25am
bob neville
You can but the new holes in the seal will be to close to the original ones and the rubber will tear and the seal will part company with the door.
I tried this on my now experimental seal and it lasted 5 minutes.
Bob
Post #84631 16th Aug 2011 7:11am
shrekman
England 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Re: New MY2011 door uderseal, who know more than me???
dgardel wrote:
Someone of us with MY2011 (late?) and have this seals installed from LR, can do photos and post it???
Seems good,
MMMMMMMM they look nice !!!! do they do the job ??
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  spent 20 years fixing them ... the dealers just wont listen !!!!
Post #85324 20th Aug 2011 12:01am
mermoto
Just fitted the new seals to my 2008 Puma. Had to drill out the existing pop rivets then open up the standard holes by 1mm. Two new holes for the edges and the new seal pops straight in to position. Job done.
Mermoto Very Happy
Post #91956 29th Sep 2011 5:56pm
elenahusky
roof seal melbourne
Hey there..!! I have been following your post since last six months and I must say I got so many useful information related to this so thank you so much for sharing it with us. roof seal melbourne
Post #130026 9th Mar 2012 11:27am
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
hi
missed this post last year ... Banging Head
Just ordered new seals! Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #130036 9th Mar 2012 12:02pm
