Home > Maintenance & Modifications > Corrosion Prevention Guide! |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 |
Always very informative postings thanks for sharing the knowledge. 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
29th Jun 2019 3:19pm |
Zag, while my truck is very well looked after here, and while I don’t really like the idea of driving on the wrong side of the road , it is clear that I have to plan a visit to you if I want that kind of detail and quality. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
29th Jun 2019 4:23pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Yes stone chip under rear wheel arch and other high abrasion areas such as axles if you go off-road. You will need about 12 aerosols (presume you are wanting aerosols) of 4941 for a 110 minimum. I charge £490 but to DIY budget for about £180 these days with ACF-50 BUT you do need a professional mask £80, plus filters £20. DO NOT breath in the acid convertor, it is lethal let alone the other products. You will damage your lungs permanently, ask me how I know!! Even with pro filters it gets through
This site gives an idea of price of kits. Rejel.com |
30th Jun 2019 8:18am |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 |
Thanks. I was planning to use POR15 Metal Prep that I already have in a hand pumped bottle rather than the aerosol acid converter. Am I safe to assume they are basically the same thing?
30th Jun 2019 9:31am |
Yes, they are Actually Metal Prep (Used to be called Metal Ready) is a water based acid convertor whilst Dinitrol RC900 is an epoxy based acid convertor. They are both only as good as you prep the metal, I.e. Get as much rust off as possible, down to bare metal if you can. You will be fine spraying Dinitrol ML or 4941 directly over the top of Metal Prep without rinsing after application, a paint product would require it however.
30th Jun 2019 8:14pm |
Great thanks. Appreciate your advice.
30th Jun 2019 8:34pm |
Thanks for all your help and advice Zag. Got the underside treated this weekend.
Click image to enlarge Click image to enlarge Click image to enlarge It’s one hell of a mucky job but pleased how it turned out. Now just need to protect the rest. |
14th Jul 2019 8:21pm |
That’s tidy work boxoftricks 2015 HT XS 90
14th Jul 2019 8:32pm |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 286 |
For those who wish to follows Zagato's pistol grip style pressure washer lance arrangement, mines just arrived from kranzle Aquaspray, part numbers as follows: - Stub Lance 12391, M22 Gun 12491
Link to website: - https://kranzle-pressure-washers.co.uk/ NormanD WE191 2015 110 XS Utility 2014 VW Caravelle 180 Executive |
15th Jul 2019 12:19pm |
Looks a nice job |
15th Jul 2019 3:16pm |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
May I add another vote for Kranzle pressure washers. I've had a K1152 TST for five years and although it was expensive, it's been out of this world compared to my previous DIY store ones.
If you're REALLY keen, after you've washed all the muck off, you'll want one of these too: https://www.cardryers.co.uk/Master-Blaster-Car-Dryer.php They're absolutely fantastic. Just don't give it a whirl in your living room when you unpack it though.... |
15th Jul 2019 7:58pm |
Def2WazzaMan Member Since: 17 Jul 2019 Location: Aberdeen Posts: 1 |
Thanks for this guide. I've been looking into Dinitrol products online. I have some rust evident around the wheel arches and noticed they produce a rust converter spray called RC 900. Does this spray work and stop any further corrosion or is it best to viist a professional body shop? https://www.tiltrak.com/product/dinitrol-rc900-rust-converter/
17th Jul 2019 2:25pm |
Thanks, high praise from a Pro |
17th Jul 2019 2:56pm |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 591 |
I received my kit from Rejel yesterday. I’m looking at treating on Tuesday while the weather is hot and it will all flow well.
I’m looking at removing bumper grill headlamp surrounds and mud flaps and brackets for access. Are there any other items I should remove (110 usw). Do the plastic trays under seats need removing? I have also seen a dinitrol guide that suggest some holes should be drilled the plugged. Is this correct. If so does anybody have a copy of the guide available. Can’t wait to get stuck into this as the lack of treatment currently really lets my truck down |
20th Jul 2019 8:06am |
