Home > My Defender > What Did You Do In Your Defender Today |
Landymatt Member Since: 31 Dec 2018 Location: York Posts: 191 |
First camping trip of the season. Just a hose pipe in a field.
But a fire pit, melted chocolate and strawberries to dip keeps everyone happy. Click image to enlarge |
26th May 2019 5:38am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3677 |
^^^ I assume the kitchen sink is in there somewhere? ๐
26th May 2019 6:39am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5846 |
Removed front prop and checked UJs and while off I greased the nipples - Part of the hunt to try and solve the wheel wobble issue (55-60mph) - some roads worse than others
Rear wheels balanced up OK as are the fronts and the tyres are OK. No play in ball joints according to the garage who had a look. Started making the mounting plate for the Eberspacher from some stainless I had hanging around. Modified the rear corner protectors I got and now these are in for blasting and powder coating. Took the rear chequer plates covers off also for blasting and coating. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
29th May 2019 8:37am |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10382 |
Hi John, have you checked the front panhard rod bushes, and or checked the bolts for tightness?
29th May 2019 8:50am |
Hi Greeni.
Replaced the bushes with gen LR ones along with new bolts/nut and same for the radius arms (all bushes and buts/bolts) - maybe a retorquing/checking would be an idea. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
29th May 2019 9:08am |
My v8 became vague this past couple of weeks, was the panhard rod bolt slightly loose.
Worth a try |
29th May 2019 9:14am |
certainly worth a poking with a Mr T. Orque wrench. 1999 Defender TD5 110
29th May 2019 9:28am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20382 |
Have a look at the steering box drop arm area that there is no play and the steering column UJ too.
Also although may not seem associated damper bushes too, they can cause all sort of feedback issues whilst driving. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
29th May 2019 12:16pm |
Whats the best way of checking UJs? just wiggle steering wheel left/right
I did think about the shocks - will also have a look at them & bushes 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
29th May 2019 2:22pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3751 |
Sorted my front lower a/c grill with stainless grill & fixingsand fitted some modern style indicators๐
Click image to enlarge Click image to enlarge Click image to enlarge Indicators are dark smoked led Knight rider style... I think they are great ๐ Click image to enlarge |
29th May 2019 8:12pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3294 |
29th May 2019 8:16pm |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
a defender from 1984 pretending to be a puma with a touch of Range Rover
29th May 2019 8:26pm |
Love it ๐๐๐๐๐๐๐
29th May 2019 9:22pm |
Drove to the Cheshire Landrover experience for a drive around their grounds. Unfortunately the defender we booked to use had broken so we ended up using a disco 5 which is very capable but Iโll stick to the defender Ray
30th May 2019 6:36pm |
