Home > My Defender > What Did You Do In Your Defender Today |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5843 |
A 147" Defender? 1999 Defender TD5 110
31st May 2019 6:22pm |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 |
130 80" 1948
Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
31st May 2019 7:01pm |
Looks longer. Maybe its the section between the front and rear doors? 1999 Defender TD5 110
31st May 2019 7:03pm |
Standard to the A pillar, extended body to the rear door, then standard 110 back end. Can sit in second row seats with legs stretched out and not reach front seats. (I am 6’2”)
Seems best way of doing it, to my eyes. 80" 1948 Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
31st May 2019 7:07pm |
Looks good. Loads of room in the back for a party. The distance from the centre of the rear wheels to the xmember looks the same as a 110. 130's to me look like the distance is greater. 1999 Defender TD5 110
31st May 2019 7:12pm |
It was a Rapier gun tractor, with low compression V8, changed to 300tdi, but td6 May have major problems, so fitting a M57 BMW unit next month.
New body fitted, 110 with a filler section in middle. 80" 1948 Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
31st May 2019 7:28pm |
Looks good! 1999 Defender TD5 110
31st May 2019 8:03pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4795 |
Interesting looking Defender 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
31st May 2019 8:30pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17387 |
Remember a standard 130 rear tub overhangs the crossmember by about 10". |
31st May 2019 9:38pm |
That be why then - cheers BW. 1999 Defender TD5 110
1st Jun 2019 9:17am |
HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173 |
Tested some new camping equipment.
Click image to enlarge |
1st Jun 2019 6:53pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10382 |
Bought another, and drove 240 miles home.
1st Jun 2019 7:34pm |
@Greeni - another Land Rover? You are the event next weekend? 1999 Defender TD5 110
2nd Jun 2019 4:47pm |
Had a look for the steering wheel wobble on the 110.
Checked; Panhard rod bolts - all tight - no play in bushes Radius arm bolts - all tight and torque checked. Steering UJs look/feel good. All steering ball joints look/feel OK; The only one I can hear some play in is the drop arm ball joint. With my ear to it I can hear a tapping noise, so that is going to get replaced. Choices between buying the removal tool and a complete drop arm or just the drop arm ball joint - both require a session of lying on the ground. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
2nd Jun 2019 4:51pm |
